Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: where did you get fittings for PE pipe?
    DIY Junior Member tikicarver's Avatar
    Feb 2010
    Tehachapi, CA
    Default where did you get fittings for PE pipe?
    I am replacing a main water line with 1 inch PE pipe.
    I have looked in several stores for fittings and all i can find are the steel fittings below.
    And all they have are the standard hose clamps, like the ones in cars to hold them on.
    The PE pipe is pretty stiff and I'm wondering if the hose clamps will work.
    Are there some other kind of fittings to use on PE pipe?
    If so, where do you buy them? any online sources?
    Nov 2010
    Maine
    You have to warm the pipe before you insert the fitting. Two opposed clamps should be used as well.
    Sharkbite, or similar, fittings would be my first choice for CTS plastic piping underground.
    Hardware stores don't carry the brass fittings. I get those at plumbing supplies. Ferguson is one that carries them.
    Steel and water on a long-term basis is a disaster waiting to happen...they will rust, it's just a question of time. Why risk it?
    Feb 2010
    Tehachapi, CA
    yeh, don';t want to use steeel, but so far that is al i can find in the the local stores.
    Lowes did have some brass fittings, but the barbed part that goes into the pipe was pretty short, it would not allow the use of two clamps.
    The one in the photo above is long enough but it is steel.
    there is a Ferguson about a hour drive from me I can go there. Anyone know of an online supplier?
    also what is the preferred way to heat the pipe?
    Nov 2010
    Maine
    Heat gun but 99% of use a torch.......carefully. You can get the same barbed fittings in Nylon too which will not rust but you need to be careful not to over tighten the clamps
    Feb 2010
    Tehachapi, CA
    is this the brass one you are suggesting?
    http://www.grainger.com/Grainger/Hos...FN7?Pid=search
    Jan 2008
    I buy stainless steel ones from Grainger.
    If you have a local well drilling company, they would also be likely to have them.
    DIY Junior Member hhplumbing's Avatar
    Oct 2012
    Victoria, BC
    If your dealing with PE, mostly we use Philmac compression fittings. Very easy to use and it's rated for underground use. note: If philmac is not sold in your area, sharkbite is rated for underground but its not the first product I buy. try and find a similar compression fitting like Philmac.
    HouseHold Plumbing Forum - Reviews and how to solve your plumbing problems . Our Journeymen Plumbers will help you out anyway we can before hiring a costly plumber when its not needed.
    Visit http://www.householdplumbing.com sign up today and get your problems solved.
    Feb 2010
    Tehachapi, CA
    I found these on line. They have a longer barb section.
    http://www.completeplumbingsource.co...bronze-adapter
    Feb 2010
    Tehachapi, CA
    Quote Originally Posted by hhplumbing View Post
    I found these guys. they said they have a distributor in my area.
    http://www.floplastfits.com/products.html
    Now i have to see if they will sell to a DIY guy.
    Feb 2010
    Tehachapi, CA
    I was able to buy the compression fittings.
    These fittings are 100% better than using a barb fitting.
    Plus they cost less, only $6.50 each.
    Now all you have to worry about is the male thread snapping off.
    Jan 2008
    Normally when working with PE one buys a big enough reel so that only one length of pipe is required for the job. This eliminates the need for any buried fittings. I don't trust plastic pipe fittings, especially threaded fittings, but have never had an issue with the stainless steel ones which are readily available.
  1. polyethylene well pipe fittings
    By oldwino in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-06-2009, 02:28 PM
  2. Can I use Qestpex fittings with Vanguard pex pipe?
    By Munkey99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2008, 11:28 PM
  3. Installing compression fittings for PE gas pipe
    By FredC in forum HVAC Heating & Cooling
    Last Post: 11-18-2007, 11:22 AM
  4. Pipe Fittings
    By azkyle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2006, 09:16 PM
  5. undoing Pex pipe fittings
    By drummertom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-13-2006, 07:17 PM
