Results 1 to 4 of 4
Thread: Need to replumb under sink for new disposal
    DIY Senior Member rsmith99's Avatar
    Feb 2008
    Oklahoma
    Default Need to replumb under sink for new disposal
    I am replacing the disposal under my kitchen sink. The new disposal is a littl bigger than the old one and the pipes need to move a little.
    The existing drain pipes are 1 1/2" PVC. All glued together.
    When I was at the plumbing supply store buying new PVC fittings, a plumber suggested I replace all the 1 1/2" PVC with the smaller, thinner, slip joint fittings to make it easier next time.
    I like the idea of easier next time, but it seems it would be better for the sink and the disposal if I kept the drain diameter 1 1/2".
    Can I get some opinions on which way to go?
    Ron
    Another plumber for the thinner PVC with slip joints. It makes it easy to take apart if you need to clean it out too.
    Sep 2009
    Seattle. WA
    The thinner tubular drain pieces are not significantly smaller than PVC in the inside diameter. Unless you have some special need
    for the added sturdiness of Schedule 40 PVC, the 1 1/2 in. tubular is the way to go, the flimsier stuff is perfectly adequate
    for the job it needs to do, and much more convenient.
    I have ONLY used the glued together drain fittings in VERY special circumstances. Otherwise everything is done with 1 1/2" tubular.
  1. disposal backup in to other sink
    By sspeed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2012, 08:38 AM
  2. Disposal/sink connection
    By thezster1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-16-2010, 06:45 PM
  3. Water comes up other sink when disposal is on
    By vlbridges in forum Drain Cleaning
    Last Post: 05-08-2009, 07:38 AM
  4. Water comes up other sink when disposal is on
    By vlbridges in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-17-2009, 08:01 PM
  5. kitchen sink disposal
    By mjrva in forum Remodel Forum & Blog
    Last Post: 06-02-2005, 06:06 AM
