Results 1 to 8 of 8
Thread: Acrylic Tub Mortar Problem
    DIY Junior Member swiederin's Avatar
    Apr 2012
    Iowa
    Default Acrylic Tub Mortar Problem
    I bought a new acrylic & fiberglass reinforced American Standard tub. The bottom of the tub has a piece of OSB moulded to it. The instruction say to use mortar to set the tub. How will this work with the OSB? It is not packing material. Need some clarity.
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by swiederin View Post
    Does the OSB make full contact with the bottom of the tub?
    Can you post a picture?
    JW
    Many tubs have OSB or wood on the bottom. I set several piles of mortar down and allow the tub to squish out the piles as it drops into place. The mortar as it drys tends to pull away a bit anyway. You can also lay a sheet of plastic down between the mortar and the tub.
    The goal of installing any tub is to get it level and have full contact with the subflooring. If you are really lucky, you may not need anything underneath it. For the vast majority of installations, though, it works out best if you use some mortar to get that full support and make things nice and level. Make sure it is level both L-R and F-B, as doing so makes finishing it up and performance easier/better.
    Apr 2012
    Iowa
    I was thinking that the mortar would need to flow into an area with ridges/gaps to provide some stability.
    Apr 2012
    Iowa
    Probably want to use some plastic underneathg the mortar as well as between the mortar and the OSB/tub right?
    Apr 2012
    Iowa
    It appears to. Do I need to change the location of the ledger boards to allow for mortar?
    Use the small piles as Terry suggested. Make the mud loose, just enough body to allow it to stand up a little, no so stiff that is will not spread out. About ten piles under the base will do it.
    John Bridge, Ceramic Tile Setter :-)
    http://johnbridge.com/vbulletin/index.php
  1. A "quick setting thinset mortar" ok for bedding acrylic tub?
    By recountryman in forum Shower & bathtub Forum & Blog
    Last Post: 05-26-2011, 02:53 PM
  2. Does this Tub have a Mortar Bed?
    By yoyoma in forum Shower & bathtub Forum & Blog
    Last Post: 08-21-2008, 03:22 PM
  3. Mortar Bed for Acrylic Bathtub
    By Howitzer17 in forum Shower & bathtub Forum & Blog
    Last Post: 08-15-2008, 07:12 AM
  4. mortar under tub
    By duct tape pro in forum Shower & bathtub Forum & Blog
    Last Post: 12-19-2007, 02:47 PM
  5. Acrylic Tub on wood subfloor and Mortar bed
    By bennybaby in forum Shower & bathtub Forum & Blog
    Last Post: 11-19-2005, 09:38 PM
