Results 1 to 7 of 7
Thread: Slow dry PVC cement.
    DIY Junior Member syncman's Avatar
    Oct 2012
    Marietta GA
    Unhappy Slow dry PVC cement.
    Hot tub repair, 2" PVC manifold fittings that cracked in winter, due to control failure.Had to cut off 2" pipe flush with manifold, and pipes have very little flex, or space, so my thought is slip an "internal repair coupling" into the pipe on one side, line up other pipe and slide half way back. Obviously regular PVC cement will grab too quickly, so I need some sort of adhesive that will give me time to maneuver things into place. I am NO plumber. Removing the fittings and replacing them is problematic, as these 5 port manifolds each have 5 pipes that then need replacing. Now I would have 1x2" and 10 x 1" pipes to replace plus a LOT of spray insulation stripping.
    http://www.google.com/imgres?hl=en&c...9,r:0,s:0,i:78
    Mar 2011
    Houston, TX
    Maybe it would be best to get a plumber.
    Just 1 leak and you have problems.
    Just thinking...
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Oct 2012
    Marietta GA
    Not just 1 leak, whole bunch. Replaced 3 manifolds already, that were easily accessible. No more leaks. The whole thing froze and cracked, pump and pipes. This is the last area of repair, so want to do it as easy as possible.
    http://www.flickr.com/photos/5898242...n/photostream/
    A repair coupling without the ridge in the center with standard PVC glue give you plenty of time.
    You just slop the glue on on go for it. Inside the fitting and on the pipe, both surfaces.
    Now looking at your pictures, that's going to be a tough job.
    You may want to pick up some more flex PVC and see if you can add a bit of extra pipe in the loops.
    looking at that "tee" I cannot imagine ANY way to repair it. A standard "internal coupling will have a ridge in the center so you cannot "lose it" inside the pipe, and since that connection is "fitting to fitting" and the socket itself is cracked, your chances are almost nil.
    Mar 2011
    Houston, TX
    It will all need to be replaced.
    Terry's idea is good for someone that wants to tackle the job.
    If it was mine I would put a heat tape or some safe protection just to keep it from freezing again.
    Sounds like a job that needs a good helper.
    Name:  Love Helper.jpg
    quote; Sounds like a job that needs a good helper.
    Some would say that a helper like that doesn't have to be GOOD. Slightly naughty would be acceptable.
  1. American Standard slow close is too slow!
    By lauras2011 in forum Toilet Forum discussions
    Last Post: 07-26-2011, 01:45 AM
  2. toilet slow to evacuate and slow to fill up after plumbing work done
    By blue lines in forum Toilet Forum discussions
    Last Post: 04-23-2009, 12:25 PM
  3. island sink drain slow/not drain & toliet slow/not flushing
    By aot2002 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-22-2008, 05:51 AM
  4. Slow Shower Drain - Not Clogged, Just Slow
    By slynchy in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2008, 12:58 PM
  5. Toto slow close not so slow anymore
    By rablake in forum Toilet Forum discussions
    Last Post: 10-29-2007, 07:44 AM
