Results 1 to 6 of 6
Thread: Surface Pumps
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Surface Pumps
    Can anyone recommend a very shallow water height water surface pump ?
    I have others....
    This pump does not need to be super robust as I'm just pumping it into a *container* in which a Zoeller will be doing the duty.
    Does such a beast exist.
    I had planned to use a wet vac for this application but you would be amazed how fast 5 gallons fill up......
    Jan 2008
    I have one of these and found it to be a very handy little pump.
    http://www.grainger.com/Grainger/LIT...352?Pid=search
    Feb 2011
    NW Ontario, Canada
    They do make shop vacs with a pump out feature.
    http://www.youtube.com/watch?v=lUAdkm-OVPk
    The Little Giant pumps with the intake on the bottom will pump down to about a 1/2" from the surface.
    Jun 2006
    I have a wayne that does the same down to 1/8. The issue is to get it primed and pumping, it wan'ts like 2 1/2" if I recall
    Feb 2011
    NW Ontario, Canada
    Time to get the jackhammer out and make a pit or buy that shop vac with pump out.
  1. Utility Surface Pumps - Zoeller Vs. Wayne
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-29-2011, 09:51 AM
  2. Submersible pump in surface well?
    By JFCarbonneau in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-12-2010, 02:24 PM
  3. Water surface height
    By Koji in forum Toilet Forum discussions
    Last Post: 03-08-2010, 10:45 AM
  4. Down spouts and surface drains
    By djdixon1995 in forum Lawn Care/Landscaping
    Last Post: 04-27-2009, 12:08 PM
  5. Surface mounted box
    By Bassman in forum Electrical Forum discussion & Blog
    Last Post: 11-17-2007, 04:32 PM
