Results 1 to 10 of 10
Thread: Using Wedi Board With Swanstone Shower Pan
    DIY Member DanMcD's Avatar
    Jun 2005
    Dayton, OH
    Default Using Wedi Board With Swanstone Shower Pan
    When using Wedi Board with Swanstone Pan, does it get installed like the Swanstone instructions for their alcove walls?
    They say the backer water proof walls should be flush with the Swantone shower pan lip and also with a 1/2 inch gap above the lip (to avoid wicking).
    Seems like their approach would let water get into the 1/2 inch gap over time. But then, I have no experience with this wicking concern.
    What do you folks think about this?
    Jul 2009
    North Vancouver, BC
    Default Wedi Board installation in shower pans
    Quote Originally Posted by DanMcD View Post
    A 1/2" gap does not sound like a good idea.
    Wedi has a sealant like Noble Company's Noble Sealant 150 and Schluter's Kerdi Fix. I would contact Bastian at Wedi and get one of his tech boys to give you a proper detail for this.
    You can reach Bastian here.
    Bastian Lohmann <bastian.lohmann@wedicorp.com>
    JW
    Jun 2005
    Dayton, OH
    Quote Originally Posted by johnfrwhipple View Post
    JW
    John, I'll send Bastion an eamil and let you know what he says. Thanks, Dan
    Jun 2005
    Dayton, OH
    John,
    I sent Bastion an email but he never answered me back.
    Dan
    Hi Dan,
    Wedi board does not wick. Set it close to the lip on the receptor and caulk it with pure silicone.
    John Bridge, Ceramic Tile Setter :-)
    http://johnbridge.com/vbulletin/index.php
    Jul 2009
    North Vancouver, BC
    Default Shower Questions answered by Wedi technicians
    John,
    Dan
    Weird.
    I'll send him an email asking him to look into it.
    JW
    Update: BAstian emailed back stating he did not get your email. He suggested you contact Peter Beckmann (peter.beckmann@wedicorp.com).
    Peter I'm told is looking after the inquires generated from John Bridge's formun and Terry's
    Jul 2009
    North Vancouver, BC
    Default Wedi Sealant or silicone with Wedi installations in showers
    Quote Originally Posted by John Bridge View Post
    Hi Dan,
    John Bridge Wedi requires the use of their Wedi Sealant - not pure silicone.
    P.S. I figured out the Vortex Fold. I never thought about "Static Electricity" as being the key step. Trickery at it's best.
    JW
    Jul 2009
    North Vancouver, BC
    Default Wedi Eco Bath shower installation with shower pan
    I got an email from Bastain saying the question has been answered. Bastian cc'd me and I thought I would post part of the solution.
    Wedi Corporation / Wedi Americas
    1100 Landmeier Road Suite 200 Elk Grove Village, Il 60007
    Office Tel. 877.933.WEDI (9334) Mobile 770.366.6835
    Mobile Fax 770.783.8874 Office Fax 847.357.9819
    http://www.wedicorp.com
    http://www.facebook.com/wedicorp
    http://www.youtube.com/wedicorp
    I have found over the past few years that getting proper answers is often more about how the question is asked and who you ask. Talking to a technical support staff member is usually the best approach.
    Hopefully this helps more people out down the road.
    Jun 2005
    Dayton, OH
    Great and thanks. That was the attachment I was trying to send but I could not make it work.
    John, also....below is the other info I got from Peter Beckmann, in addition to his attachment info that you just provided:
    Hi Dan,
    Thank you for your interested.
    You want to cut out a notch on the back side of the wedi board, apply a continuous bead of wedi joint sealant to the inside of the tub flange and install the wedi board to the framework, so that the tub flange is integrated into the wedi board. wedi board can be installed down to the actual tub edge the tub edge leaving only 1/8” gap to alow for movement. Wedi board cannot wick water unlike fleece/paper laminated foam boards, gypsum or cement boards. It will fully back your tile all the way down to the edge of tub. Plumb, Square and tight corners are the result of the tub flanges safe integration into the wedi board. see the tub surround Kit TDS attached – It shows the installation method in detail
    Please let me know if you have any further questions.
    Thank you and have a great day
    Peter
    Sincerely,
    Peter Beckmann
    Technical Support Manager Midwest/Center
    Jul 2009
    North Vancouver, BC
    Default Wedi Board - Techinical Questions answered by Peter Beckman (Techinical Support Mgr)
    Hi Dan,
    Peter
    Sincerely,
    Peter Beckmann
    Thanks for sharing Dan. For those people reading this thread there is a big difference between Silicone and Wedi Sealant (Re: Post #5 by John Bridge).
    Careful what you read online and check with these product manufactures technical departments before following advice gained online.
    If your having a hard time reaching them. Send me your question and I'll give it a go. I have come to know these men quite well over the past few years. I ask a lot of questions!
    JW
  1. Waterproofing Walls for Neo Angle Shower Using Wedi Board
    By DanMcD in forum Shower & bathtub Forum & Blog
    Last Post: 10-21-2012, 06:06 AM
  2. WEDI walk-in shower base construction
    By danboston in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2011, 03:03 PM
  3. Mortar bed for a Swanstone shower pan
    By Ross Hunt in forum Shower & bathtub Forum & Blog
    Last Post: 07-16-2008, 05:59 AM
  4. Swanstone Shower Pan Installation
    By philgristle in forum Shower & bathtub Forum & Blog
    Last Post: 07-23-2007, 06:12 AM
  5. How much green board or cement board for shower
    By jeffxjet in forum Remodel Forum & Blog
    Last Post: 10-26-2004, 11:00 AM
