Results 1 to 4 of 4
Thread: Corroded copper, Need to be replaced?
    DIY Junior Member prestonv's Avatar
    Dec 2009
    san diego
    Default Corroded copper, Need to be replaced?
    I have some copper pipes that look like they are corroded pretty badly. I had a plumber over (on another issue) and he said they will spring a leak if left unattended and should be replaced. Pipes are in the crawl space under the house. The first photo is a side view and the second photo a view from beneath. Both pipes are cold water pipes and they are touching each other. Area is bone dry and there are currently no leaks. What do you think? Replace, just ignore or sand the corrosion off and slide some plastic between the pipes? Comments appreciated.
    Thanks.
Size:  61.9 KBName:  PICT0101.jpg
    Jan 2008
    I would clean it with a scotch-brite pad to better see what the pipe really looks like after the verdigris is removed.
    It wouldn't take much time to drain the system, cut that out, and replace it.
    I would be more concerned about WHY it happened at that location. But clean the tubing and check its condition. That is often just an exterior coating on the tubing.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    In the second picture, at the cross, it looks like the upper pipe was previously repaired. If so, maybe the guy got flux all over the place and didn't clean up? Just a guess, though
  1. Corroded pipe nipples
    By Pixburd in forum Water Heater Forum, Tanks
    Last Post: 05-16-2011, 09:51 AM
  2. 3yr old SS pump motor corroded AGAIN
    By blown in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2011, 07:46 PM
  3. Corroded threading help
    By pocoloco in forum Plumbing Forum Discussion & Blog
    Last Post: 08-09-2009, 07:52 PM
  4. corroded vent piping
    By homerwannabe in forum Toilet Forum discussions
    Last Post: 10-29-2006, 03:24 PM
  5. Corroded Tub Drain
    By phxrt in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2006, 12:04 PM
