Results 1 to 5 of 5
Thread: Kitchen drain
    DIY Junior Member Lar-bear's Avatar
    Nov 2012
    Amherst, NY
    Question Kitchen drain
    I just purchased house and i'm remodeling kitchen. The current kitchen sink drain is 24 inches from floor to top of 1 and 1/2 inch drain pipe. My sink is 9 and 1/2 inches deep and will be mounted under granite counter top on a sink cabinet 34 inches high. Will I be ok with just 1/2 inch difference. I will not be installing disposal.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    You will need to relocate the drain. More clearance is needed.
    Open the wall up now while you are doing the remodle.
    Michael
    Sac City Plumbing
    http://SacCityPlumbing.com
    Jan 2008
    You need more room, and flexibility for future changes.
    I would shoot for 15-16" off the floor to leave room for a disposal.
    I think 15" to 16" is becoming the new standard too.
    Without the disposer, you might be able to do 19", but for those three inches, and for a future alternate universe decision, I would do 16" and call it good.
    You have 1 1/2" from the bottom of the sink, NOT from the bottom of the sind drain you will have to install in the sink. Even if you did have 1 1/2" unless you used a "low inlet trap" which are very unstable, the inlet would be above the pipe in the wall. NOTHING will work other than moving the drain line or getting a different sink.
  1. Add a drain line for a kitchen sink to an existing drain line for a washing machine?
    By Loflow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2011, 05:49 AM
  2. Kitchen Drain
    By K2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2010, 11:41 PM
  3. Adding Laundry Room Drain to Kitchen Drain
    By lukus in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2008, 01:15 PM
  4. Kitchen sink drain
    By Time1992 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2007, 09:37 AM
  5. kitchen drain
    By jpiazza in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-02-2007, 07:03 PM
