Results 1 to 13 of 13
Thread: Schluter trim and my install
    DIY Member boardable's Avatar
    Sep 2012
    San Jose, Ca
    Default Schluter trim and my install
    Ok so I did my curb last night and used schluter trim. I did this because my tile did not have edge tiles available and instead of making my own edge ( which i should have) I decided this would be easier. So next time I say " I am planning on doing a NEO angled shower and using Schluter trim, please someone remind me to NOT do it. PITA and took me 3 hours to get it all done. Here is the picture ( yes it is missing a few little peices I still need to do tonight.
    Feb 2011
    NW Ontario, Canada
    If you think that little bit was fussy, look at what I was faced with. There is not only brushed nickle edging around the niche but also embedded in the transition between the glass tile and field tile. The flash doesn't do it justice.
    Feb 2011
    NW Ontario, Canada
    Here is a before pic.
    Sep 2012
    San Jose, Ca
    OMG That is Beautiful. It is just the angles that killed me. For the niche's i will just bullnose my tile. No metal for me I am really over the profiles.
    Jul 2009
    North Vancouver, BC
    Boardable next time try doing your curb in phases and not all at once. Installing the dry side (bathroom side) face tiles first will give you a good base. Then use a profile a little taller than your tile. This way you can keep it flat to the face tile and still pitch the top tile. Does that make sense?
    A baby chop saw with a non-ferrous blade works wonders on those Schluter profiles.
    JW
    "When it's Perfect. It's good Enough." - John Whipple ...................... Q: Who are the Top Ten Bathroom Designers for 2010-2012..? ANSWER
    Contact Info: Email jfrwhipple@gmail.com Phone: 604 506 6792 Alternate Email: info@byanydesign.com
    Sep 2012
    San Jose, Ca
    John, I have a huge chop saw at my shop. Too large for this so out came the dremel with the metal cutting blades. Blah, I will be now using my amature buffing skills to make the edges look good. Made my own bullnose tiles for the niches and much happier with that. Next time I will be doing the same for the curb. Saddly my tile saw only cuts either streight or 45 angles so the edge is not like traditional bullnose but still looks great when you cut the tip off. God niche's take alot of time. But they look great. Getting them perfect is going to take some practice. I used the EZ niche cut outs before and do not like them since they stick out onto the face. Building them from scratch is best.
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by boardable View Post
    The effort that goes into a niche is huge. Worth the work. Every one loves them.
    Are you going to add in any LED Shelving?
    JW
    Sep 2012
    San Jose, Ca
    Wow that is awesome. Where did you get the shelf? is it installable after tile is in as I am already almost done with my niches
    Jul 2009
    North Vancouver, BC
    The shelf is just some 1/2" Starphire glass. I installed the lights and the track before the tile.
    JW
    DIY Junior Member clapfc's Avatar
    Nov 2012
    albany ny
    Damn, you do nice work. That came out beautiful.
    CLAPFC
    Jun 2009
    Canada
    Why can't we see any thinset around the seams on the Kerdi?
    Sep 2012
    San Jose, Ca
    Because he is a pro. He is clean with his thinset. Me on the other hand. It looks like it sneezed thinset all over hahaha.
    Jun 2009
    Canada
    He isn't a pro.
    I'd be more worried about leaks than I would a "clean" looking kerdi seam.
  1. Schluter Kerdi Membrane Source?
    By inertiacoupling in forum Shower & bathtub Forum & Blog
    Last Post: 03-30-2012, 06:07 AM
  2. Schluter's Line Drain - A closer look at the new linear shower drain from Schluter
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 07-15-2011, 07:47 AM
  3. Orange Mold in a Schluter Systems Kerdi Shower - Linear Trench Drain
    Last Post: 06-14-2011, 08:54 AM
  4. Schluter-Kerdi shower install needed
    By cclearly in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2008, 01:06 PM
