Results 1 to 7 of 7
Thread: Hydro Pneumatic Tank, Low Water Pressure
    DIY Junior Member Eliz1's Avatar
    Feb 2010
    Knoxville, TN
    Default Hydro Pneumatic Tank, Low Water Pressure
    After suffering through a weeks worth of showers with dismal water pressure I have finally investigated some and need guidance. When no water is running the pressure gauge on the tank reads 45 ( I seem to remember it normally being at 60psi). Turn on a faucet, the pressure drops to 40 and the pump turns on. Pressure rises back to 60, the pump stops and the pressures starts dropping to 40 and the cycle begins again. FYI this is a hydro pneumatic tank and is approximately 6 yrs old. I read the helpful sticky on pressure tanks but I want to make sure I'm on the right track before I go and tinker with things. Any advice on what the problem might be or how to fix it is appreciated.
    Thanks,
    Elizabeth
    Feb 2011
    NW Ontario, Canada
    From what you say it sounds like the pressure switch is set to turn on at 40 and off at 60. The pressure would only stay at 60 if you stop using water before the pump turns off. If you draw water after the pump turned off, the pressure will drop. If you use enough water for it to drop to 40, the pump starts up and so the cycles go.
    So far you have not described anything that would suggest "dismal water pressure", only normal operation.
    Feb 2010
    Knoxville, TN
    Hmmm. Normally I have great water pressure and it has definitely decressed so I wonder what is causing it. We are on a slab so I'm not sure how to check for leaks in the pipes.
    Feb 2011
    NW Ontario, Canada
    If you had a leak, your pump would be cycling without any water use.
    Feb 2010
    Knoxville, TN
    Well that is good news! No leaks! I will keep poking around. I remembered that the other shower had this problem once and it involved a clog in the shower valve. When I have a moment I will see if I can take it apart, investigate, and report back. Thanks for your help.
    DIY Member bcpumpguy's Avatar
    Jul 2012
    Langley BC
    Quote Originally Posted by Eliz1 View Post
    do you have any filter housings anywhere?
    Feb 2010
    Knoxville, TN
    Hi bcpumpguy,
    We do have a very simple filter attached to catch silt and I have taken it off and cleaned it. I might be over stating it when I say dismal water pressure. It is just less than normal. I haven't taken apart the shower valve yet as I haven't had time. But I suspect this isn't my problem since the lack of water was more pronounced in the shower that had that issue. I am really puzzled by the pressure gauge on the tank being at 45 psi since I am almost positive that it normally idled at 60 psi.
  1. Water level in an air over hydro tank
    By SilverFox52 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-10-2012, 04:58 PM
  2. well-air hydro pneumatic well tank
    By kyleesmom0335 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-22-2010, 09:12 AM
  3. Hydro-pneumatic vs. captive air pressure tank
    By HardH2O in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-01-2009, 10:18 AM
  4. Replacing Hydro Pneumatic With Bladder Tank
    By Brushfire in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-08-2009, 10:25 AM
  5. Hydro Pneumatic Pump Tank
    By Davidl69 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-04-2008, 03:41 PM
