Results 1 to 2 of 2
Thread: Return of sewer smell
    DIY Junior Member ncmg's Avatar
    Oct 2012
    North Carolina
    Default Return of sewer smell
    Two months ago I replaced the wax ring on a toilet due to a strong sewer smel. The odor went away immediately. However it is now back! Any ideas on why? I don't see any cracks in the porcelain, there is no apparent water leaking and the toilet functions properly. The toilet is late '80s and I replaced the ring with an Oatley reinforced standard size (flange is slightly above floor level). Thank you for any input!!
    Apr 2012
    New York, NY
    Could be a lot of reasons but one is if the toilet is rocking or otherwise moving, the wax seal could be breached. It doesn't snap back into place, so if it was the seal last time, it may be the seal this time. Simplest explanation first. If the toilet is rock-solid, then maybe something else.
  1. Getting Rid of Sewer Gas Smell
    By RRGuy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2012, 01:45 PM
  2. AAV and sewer smell
    By bmcgin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-28-2010, 02:01 PM
  3. Sewer Gas Smell
    By inspectorjimo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2007, 06:01 AM
  4. Sewer Smell
    By glendap in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-24-2006, 03:53 AM
  5. sewer smell from tub
    By LJS in forum Toilet Forum discussions
    Last Post: 10-17-2004, 07:43 PM
