Results 1 to 6 of 6
Thread: Recess lighting
    DIY Member Barry J's Avatar
    Mar 2007
    Mass
    Default Recess lighting
    I am installing recess lighting in my finished cellar room, I have suspended ceilings.
    The gap between the bottom of the joist and the top of the ceiling tile is 2 1/2 inches, but the most my can light ajust to is 1 inch lower. So if I mount it to my joist ..it won't reach the top of the tile.
    I know I can mount it on the ceiling frame, but is there a way I can do it on the joist??
    It's my first time with recess lights, does the "baffle" assembly somehow cover that gap of 1 1/2 inches??? The instructions that come with it is minimal.
    Barry
    Jun 2007
    North Carolina
    Quote Originally Posted by Barry J View Post
    Barry
    Herein lies your answer. The instructions will tell you if you can or if you can't
    Feb 2011
    NW Ontario, Canada
    Why don't you just scab on or cross-strap on a 2 inch piece of wood to the bottom of the joists to lower the cans? I would not trust mounting it to the suspended ceiling frame.
    Mar 2007
    Mass
    Alright, seems like either add more wood, or mount onto the frame...frame appears to be pretty stable,
    I've got 6 lights to put up and retrofitting all those lights with wood, seems like frame mount is way to go
    any negatives with installing on frame???
    Jun 2007
    North Carolina
    Most every recess fixture I have installed in a lay-in ceiling was mounted to the ceiling grid.
    Every recessed can I have ever seen has adjustments for the depth of the can.
    What brand name can are you using?
    DIY Junior Member Undfusk's Avatar
    Nov 2012
    Colorado
    visit this.
    Barry
    Which technology recess lights you have purchased?
  1. Air tight trim for recess lights
    By ingeborgdot in forum Remodel Forum & Blog
    Last Post: 08-03-2010, 08:10 AM
  2. lighting needs
    By milkman2010 in forum Electrical Forum discussion & Blog
    Last Post: 11-15-2009, 06:57 AM
  3. Lighting
    By Cookie in forum Electrical Forum discussion & Blog
    Last Post: 01-27-2008, 05:40 PM
  4. Lighting Near Tub ?
    By statjunk in forum Electrical Forum discussion & Blog
    Last Post: 11-06-2007, 05:19 AM
  5. Lighting
    By Jed54 in forum Electrical Forum discussion & Blog
    Last Post: 08-13-2007, 07:41 AM
