Results 1 to 11 of 11
Thread: Not sure which route to go for gas line??
    DIY Member Gnfanatic's Avatar
    Aug 2008
    New Jersey
    Default Not sure which route to go for gas line??
    Hey guys, hope all is well I am converting my 12x10 breezeway into a kitchen. the breezeway is on a slab which is right next to the house foundation/basement. I need to run a gas line to the other side of the breezeway for the gas stove. What would be the best route?? Cutting into the slab and running a plastic gas pipe OR running black pipe through the attic , down the wall?? The attic is completely exposed (no sheetrock or insulation currently). I need to cut into the slab for the sink drain anyways but not sure what to do with the gas.
    I appreciate your help!
    Ralph
    Ralph
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Take gas pipe overhead,
    never ! Ever ! Under concrete
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Aug 2008
    New Jersey
    That is what i thought. Obv a few 90 degree and 45 degree bends is going to effect pressure. will 3/4 in line be fine for a 4 burner stove??
    thanks!
    Ralph
    Yakima WA
    May I assume you are pulling permits for this addition? Does your state, county, and/or state allow you to do gas work? Many places are very touchy about these things. If you do your own work without a permit, you could very well have a problem with your insurance. The advice given is correct, but you could be headed for problems.
    Aug 2008
    New Jersey
    Hey Gary, yes i am. I am doing the rough work and will have the plumber connect it to the main line and pressure test it. thanks
    Ralph
    The city is allowing you to build a room "addition" to the house on a concrete slab that does not have a foundation and footing, which few carport slabs have? I would never let the customer install a gas line because when I test it, it might have to take it apart to repair leaking joints. There are ways to run a gas line under concrete, but they are very specific and expensive, so they are usually only used for natural gas to an island cooktop.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Quote Originally Posted by Gnfanatic View Post
    You will have to recalculate the sizing all the way back to the meter. 3/4", or even 1/2", may be enough, or you may have to replace some or all of the existing pipes to make it right. Can't say without a diagram of what you have. There is a simple procedure spelled out in the code book for figuring this out.
    Also, I would leave the combination of plastic+gas to the pros -- including not some handyman at $8/hour.
    Assuming you are allowed to, I wouldn't even think about touching any gas piping until after reading, understanding, and then re-reading the code plumbing code. After that, be sure to pull permits and have your work inspected...
    All that said, gas piping isn't that hard for a skilled DIYer (after a lot of learning up-front).
    Aug 2008
    New Jersey
    thanks guys. HJ, this is a 6 inch slab. many houses are built on a slab and of course it has a footing.
    Ralph
    Here, the majority of houses are "built on a slab", but most carport slabs do NOT have foundations, other than "pads" for the support columns.
    A foundation goes below the frost line. I would guess that New Jersey has a more stringent code for foundations because of the colder weather.
    hj's comments, which mirror my experience....admittely not east coast/cold weather experience.....is that patios, breeseways, etc are not built on the same 'quality' of slab structure as the house itself. I guess you have...or will....verify all this.
  1. How to route piping
    By Bodrey in forum Plumbing Forum Discussion & Blog
    Last Post: 08-16-2010, 10:14 AM
  2. Pipe Route Question
    By ptomt77 in forum Remodel Forum & Blog
    Last Post: 05-15-2010, 02:11 AM
  3. Re-route line to shower head?
    By Tyson in forum Shower & bathtub Forum & Blog
    Last Post: 01-10-2010, 08:41 AM
  4. Re-route Vent Pipe
    By jengels2002 in forum Toilet Forum discussions
    Last Post: 11-22-2006, 09:02 AM
  5. Best way to route pipes
    By bgoldenson in forum Remodel Forum & Blog
    Last Post: 01-01-2006, 06:52 PM
