Thread: Connect septic pipe to septic tank????
    DIY Junior Member Blueboat's Avatar
    May 2012
    Arizona
    Default Connect septic pipe to septic tank????
    I am running 3 inch ABS from the house to the septic tank, there is about a 4 to 5 inch hole in the cement lid of the septic tank. What goes between the tank and the 3 inch pipe to connect the two? Is there some kind of fitting?
    Thanks for your help.
    Mike
    Your pipe goes into an opening on the "end" of the tank, NOT into the lid. There should either be a hole for you to stick the pipe into, or a piece of pipe for you to connect to. Openings on the top of septic tanks are for cleanout purposes ONLY.
    May 2012
    Arizona
    Thank you hj.
    Mike
  1. Septic Tank Odor - Vent pipe (Why now?)
    By Longjt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-29-2012, 09:38 AM
  2. Septic Tank Elimination: Does it make sense to install new toilet drain pipe?
    By amateur plumber in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2011, 11:52 AM
  3. septic tank
    By HAMLIN in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2009, 05:50 AM
  4. Septic gas belching past full p-traps/ Septic tank drainfield failing? Venting issue?
    By ryan100 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2008, 06:49 PM
  5. Need septic tank/leeching pipe advice
    By SD44 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2008, 02:41 PM
