Results 1 to 2 of 2
Thread: uv filter on well
    DIY Junior Member wowbw7's Avatar
    Oct 2012
    Minnesota
    Default uv filter on well
    need some help with installing a UV filter please. I have a rural well that free flows into a 200 gallon cistern in the basement. from there it is pressurized , run thru 3 filters, water softener then on to the house. I'd like to install a UV filter to kill any little live organisms, etc that may be in the water. the water flows into the cistern at about 50 gallons/ hour. my question is: can I install a 2 gallon/minute UV filter on the supply line going into the tank (thereby killing everything before it enters the system) or do I have to get a larger (ie. more expensive) UV filter and install it after the tank, where the flow rate is maybe 5-6 gallons/minute? any input would be appreciated
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I would mount it after your cistern and after you mount it, it is essential that you thoroughly chlorinate the entire system in order to kill any bacteria in the pipes. Run the chlorine through each and every faucet (hot & cold), toilet, out door spigot, shower, washing machine and your dishwasher. The bulb will need to be replaced every year and I usually replace the quartz tube as well.
  1. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum Discussion & Blog
    Last Post: 03-03-2011, 02:04 PM
  2. Is it possible to over filter?
    By gebishop in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-30-2010, 05:20 AM
  3. Filter Housing Help
    By kristof in forum Plumbing Forum Discussion & Blog
    Last Post: 04-22-2009, 03:07 PM
  4. Drill or Filter, what would you do?
    By drick in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-18-2008, 06:55 AM
  5. Filter moved
    By kd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-31-2007, 07:19 AM
