Results 1 to 8 of 8
Thread: need to descale my tankless heater can you use a sump pump
    DIY Junior Member loki993's Avatar
    Aug 2012
    Michigan
    Default need to descale my tankless heater can you use a sump pump
    I have to descale my tankless water heater. I've lost a bit of flow on the hot side apparent and its affecting the water pressure ion the shower.
    I have what I need but I didn't want to go spend the only on a pump if I didn't have to. I went to my dads house and he has a half horse sump pump he said I could use. Now I'm not sure but I'm afraid that it could be too much flow/pressure to do the descale.
    Can you cause damage to the unit by using too powerful a pump or should I be ok using the sum pump?
    Feb 2011
    NW Ontario, Canada
    Most sump pumps are between 30 and 90 GPM while descalers generally are a tenth of that. Also descaling pumps are resistant to the acid used. Not sure what the acid might do to a sump pump.
    Aug 2012
    Michigan
    Im just using vinegar, nothing serious, the pump should hold up. Im just worried that it may be too much pressure.
    DIY Member Killer95Stang's Avatar
    Mar 2012
    Southern CA
    A 1/2 hp unit seems like a huge overkill to descale a tankless. I'll be using a 1/6hp pump I picked up at HF... I'll check in to post the results once I'm done....
    Mar 2012
    Southern CA
    So.. Yesterday I completed my 6 month descaling of my Rheem Condensing Tankless water heater. I used the 1/6hp pump below that I purchased at HF with my 20% coupon. I then sourced two 6ft washing machine hoses, since they already have the needed FPT hose ends installed. I used a clean 5 gallon bucket filled with 3.5 gallons of white distilled vinegar. I first bypassed my tankless from the house water system using my installed service valves, then drained the waterheater. I connected the hoses to the WH and circulated the mild acid solution for 45-60 minutes. After, I flushed the WH twice with clean water using the same pump and bucket, then cleaned the small filter of loose debris.
    All said and done, the process was pretty uneventful. I ended up spending about $70.00 for all the supplies needed, which is way cheaper than buying one the $169 pre-made kits.
    Aug 2012
    Michigan
    Quote Originally Posted by Killer95Stang View Post
    Yeah I think its overkill too, but the pump didnt cost me anything. I was trying to avoid the biggest cost of the job which is the pump. However Im not going to risk damaging the unit to save some money. Maybe I can run across a pond pump on clearance somewhere.
    DIY Junior Member saphman's Avatar
    Jan 2012
    Northwest Florida
    I agree with you. I have the 1/6 hp pump I bought at lowes. It has just the right amount of pressure and flow.
    Another option to descale is using "SULFAMIC" acid powder. This is available through LOW ENERGY SYSTEMS and comes in a 5lb bag. There is a copper protector solution that you add with the powder to a gallon or so of water that is red. When the descaler has circulated and done it's job the water turns clear. It is better than vinegar IMHO.
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    Quote Originally Posted by saphman View Post
    The sulfamic acid certainly sounds well-suited to the job of descaling. How about a link to this "copper protector" solution?
  1. Should I replace recirc pump for my tankless heater?
    By philefriendly in forum Tankless Water Heater Forum
    Last Post: 11-07-2012, 08:00 AM
  2. Tankless water heater, recirculation pump?
    By Homeownerinburb in forum Tankless Water Heater Forum
    Last Post: 03-27-2012, 01:02 PM
  3. Tankless water heater, recirculation pump?
    By Homeownerinburb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2012, 12:04 AM
  4. Navien Tankless Water Heater---Well Pump Setting
    By JTCA in forum Tankless Water Heater Forum
    Last Post: 11-07-2010, 02:53 PM
  5. Reputation of ABS Robusta sump pump / sump pump configuration issues
    By ct-esq in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2008, 06:41 AM
