Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 52
Thread: Iridescent Particles in Ardex's 8+9 Waterproofing - A closer look
  1. #16
    Jul 2009
    North Vancouver, BC
    Default Ardex 8+9 Product review for 2012
    Post(s) removed by John Whipple
  2. #17
    Jul 2009
    North Vancouver, BC
    Default Gassing in Ardex 8+9 - Tiny pockets of air
  3. #18
    Jul 2009
    North Vancouver, BC
    Default Air pockets in Ardex 8+9
  4. #19
    Jul 2009
    North Vancouver, BC
    Default Irridescent layer on Ardex 8+9 - film layer on flood test
  5. #20
    DIY Junior Member Daler's Avatar
    Aug 2010
    Cowichan, BC
    Question
    Heya, John
    Don't know if this is the proper thread to talk about this or not...
    It's an interesting -- and timely-- review that you are doing. Too bad it's taken more than a year to complete it to your satisfaction
    I am a layman homeowner who is just now putting in a 'custom' shower (36x58). My plan is to attempt a mud floor with a Kerdi drain, and cover it with Kerdi cloth (just enough material for the floor was given to me some time back) then up the sides about 8" with Kerdi-band. I'm not concerned with any warranty program so I'm thinking on using some Ardex X5 thinset under the Kerdi as well as for the field tiles -- that product was such a good choice for my other marble-tiled bath project. Have you used X5 under Kerdi?
    The shower walls are just now Hardi'd. I then plan on using the Ardex 8+9 for the walls with overlap down onto the Kerdi clothed pan.
    The Ardex package directions indicate that the Hardi seams and corners be filled and mesh-taped with the 8+9 -- no mention of pre-filling with thinset. But some of the gaps in the Hardi are large (about 1/4" at the niches for example). So what I propose to do is to first simply fill the Hardi with thinset and mesh-tape (as normal) then treat with the Ardex 8+9 as I did using the AquaDefense on my previous tub surround project. But my uncertainty here is with with the treatment of the corners as with the possibility of 2x4 stud movements. So, do you think the option of fully thinsetting the Hardi first would have any merit? As an aside, I've used Schluter eke for corner tile movement before and it seems to have worked as well as silicone.
    Also, can the Kerdi be glued together successfully using the 8+9, or should I stick with the X5 or even Kerdi-fix? ..I'm not sure of your results as your review has yet to be finished.
    And if so is there any advantage of just continuing the 8+9 over the whole Kerdi covered pan as a backup waterproofer? -- will it stick for the long term?
    After resolving this, I also want to include building of a proper (low profile) curb. I figured I'd build it out of formed concrete. Is there a cationary method to use in doing this? I would also cover this with the Kerdi cloth ..and perhaps with a coat of 8+9 as well.
  6. #21
    Jul 2009
    North Vancouver, BC
    Default Ardex 8+9 with Kerdi
  7. #22
    Aug 2010
    Cowichan, BC
    ..continuing the conversation..
    [QUOTE=johnfrwhipple;366320]Heya, John
    Sorry for the delay. I finally got an Ardex rep out to look at the slick that forms and I'm waiting on Don (Don Brcetic 778-870-5101) to do some training. This new Ardex rep was great and so helpful. He offered to come on our next job and review my procedures to see if my mixing technique is flawed. The Ardex 8+9 is the most promising new to me product I've come upon in a long time. I love it but think it is quite hard to mix properly. The proper paddle is a must and so is the size of bucket and the volume of each batch. If you use it do not do so until you test your product first. make a "Ardex Duck Box" and flood it out. If the liquid froze in transit you could have a failure looming.
    The paddles I've been using for my thinset are like these I purchased at Princess Auto -- one small, another larger
    http://www.princessauto.com/pal/prod...n.-Paint-Mixer They seem to mix really well. Getting a genuine one from local supplier may be difficult here on the Island.
    I'm not a fan of Kerdi on the floors - it's so thin. You can get Kerdi DS now which we just installed and it's a much better product for shower floors and steam rooms. Kerdi Band is for seams not walls. So if your plan is to run the Kerdi up the wall 8" use Kerdi and not Kerdi Band. Schluter also makes some great inside and outside corners.
    I was already given the standard Kerdi cloth for free and so I want to use it. Hence, my thoughts on going over it with 8+9 to be sure on thickness and durability. Yes, I can also use the standard cloth in place of the transition band going up the wall to meet the 8+9. There were some inside corners that came with the Schluter drain. Also, in John Bridge's book he illustrated a method of cutting his own corners
    I have not but used loads of the X5 and love it as a basic thin set. Email Harrison from Ardex (Harrison Gardner Ardex Tec <Harrison.Gardner@ArdexAmericas.com>) he is there tech and he can let you know his thoughts on your plan.
    Just now doing a bit of research it seems that Ardex states that their thinsets are compatible with the Schluter Kerdi ..however, here in NA Schluter will not acknowledge the Ardex claim. I don't really care as the evidence points to numerous installers using modified thinset with Kerdi cloth, and Ardex being the best for that approach. I just wanted to see what your experience was with it as well.
    Backer boards are thirsty - all of them. And not ready for any waterproofing until they are taped and screwed off properly. Can you post a picture of your wall prep or email me so I can check how you did? What screws and what spacing etc... Of late we are making it a habit to scratch out the entire wall board during the taping procedure. This has greatly improved our working time and bond strength to the backer board. Anything over a 1/8" gap and my apprentice would be bitched out to no end. If you have 1/4" gaps in your backer board you are not off to a great start and should take measures of improving this.
    Here are some pics of my project. Lotsa screws, eh
Size:  26.7 KBName:  IMG_0177.jpg
Size:  24.4 KBName:  IMG_0179.jpg
Size:  28.6 KBName:  IMG_0180.jpg
    Note: the "wrinkled" look of the Hardi on the back "pony" wall where they join is actually some Hardi that was ground down to blend in with the bottom board. For some reason the latest batch of Hardi was a different thickness to the older stuff left from last project -- blech!
    Having tried the authentic Hardi screws without much success (too hard to drive) I instead used 1 5/8" coated deck screws. They worked great on my last bath project ..but that's only been less than a year ago. I installed them 8" apart on average, 3/8" from the edges, and 2" back from the corners. However, some of the edges broke out when trying to hit the studs on an angle (should have put in more blocking I guess). You can see some of the damage in the pics. Also, the Hardi had to mate up to greenboard drywall in the rest of the room. Again, that's where most of the large gaps are. The 9x24" niches are on either side of the valve. The niches are covered with Hardi as well. The backs of the niches will be covered after installing the drywall on the other side (closet) of the 'wet' wall -- I guess the Hardi can be glued to the back side of that drywall?
    But some of the niche meet-ups are larger than 1/8". These larger voids are why I was concerned about following Ardex instructs that yak about using 8+9 to fill all Hardi voids with their membrane and fg mesh.
    Your comment (below) about filling in all the joints with thinset and fg mesh makes me feel more confident about what I propose. I just hope I can overcome the big gaps with some stability. Perhaps the 8+9 over all that will go a long ways in holding it all together
    Do you have stucco mesh? Any Ardex X32? Ardex S14? Your waterproofing product should not be asked to seam gaps in your wall board. This is crazy to count on the waterproofing to add structure. Board. Tape with ideally a 4" mesh on the inside corners and a 6" tape on the outside corners. Small batches of rapid set, self curing thinset like the S14 work well. X5 and a few days cure time before waterproofing works to.
    Yes, I got some galvanized expanded metal for the mud floor. Is this what you are referring to? I was planning on continuing on with Ardex X5, then X77 for the large format tiles we plan to use in the shower. We also got some stiff fg mesh cut to 10" wide x 20ft long (that was for the 8+9). And of course, some alkalai-resistant 2" fg mesh tape I used from the last bath project (on the seams of the Hardi).
    I asked Dale Kempster (<DKempster@schluter.com>) what the equivelent of Kerdi Col is and was told it was Ardex 8+9. I have done a lot of testing and multiple products with Ardex 8+9 and Kerdi Corners, Kerdi DS and Noble Seal TS. All my testing has resulted in sucessful installs. All projects and test boxes where flood tested, my last for almost four days. Not a drop of water lost on any. The test boxes when finished we like to break apart. Some simple tests with liquids allowed us to use hand strength only to demo. The Ardex boxes require a good boot or two from the steel toes. Pretty impressive. Both my apprentice and I love the stuff. The X32 is pricey but so worth it. The 8+9 has been around for twenty years.
    I guess that's what I wanna hear, John. I cannot afford to do test batches with expensive 8+9, only to then throw it out. It's why I've come to this site to see what the pros have discovered. And it seems like you have succeeded in satisfying the research.
    Go to the UK or German Schluter site and watch their installs. Ask yourself why they use Kerdi Col. Then email Schluter and ask if you can buy it here or what the North American equivalent is. Then email Ardex and ask about their ten year warranty with Kerdi - that's twice what Schluter will give you. Why do they double Schluter's warranty? Perhaps because it's twice the system. I alwyays hated the "Air of Bad Blood" I picked up on when my Mapei rep and Mapei tec's bitched about Schluter. Does not give me a warm fuzzy feeling when the setting material company I was using dislikes the Schluter product. Then I stumble upon Ardex and not only do they play nice - the warranty is double. This is a no brainer.
    I've also wondered about the constant conflict some have had with the "us vs them" approach too. Both Ardex and Schluter are European products and they seem to make nice with one another there. It only appears to be a semantical problem here in NA -- go figure.
    The first time I heard about Ardex was from another Schluter rep at Fontile. We where debating exterior decks and he mentioned the long history overseas with Ardex and Schluter. This rep mentioned something about better technology and I passed it off as a tiss at Mapei (I was wearing a Mapei fleecy at the time). Then I start seeing Ardex bags on so many job sites. Not low end reno sites but multi million dollar homes we wear on. HMMM. Then the kicker is the owner of Quick Drain and I where out for lunch and he tells me to try X32. I did and I love it. This coupled with my Mapei rep pissing me off was all it took to switch setting material companies. We are very happy we made the change and love all the products so far.
    I first heard about Ardex from the front end guy at the local supplier. At that point I had just discovered Kerdi for shower building. All the competitors (Prova, etc) were using modified thinset for essentially the same type of cloth membrane, and only Schluter said NON-modified -- wtf. The counterman suggested the Ardex thinset (X5 in my case) for use with everything tile ..including Kerdi. He told me Ardex officially endorsed its use with Schluter products. I used it in my first bath project on the large marble wall tiles and it was so nice to use (at least for this amateur). Then it was kinda reinforced for Kerdi use on various online forums.
    I have yet to test their grout and have been told they are still fine tuning this for North America. I have been told that Mapei's Ultra Colour Plus can be used in lue of Ardex's products but you better confirm this yourself. I do not have this on paper or by email as yet.
    The only grout I have used has been from Mapei. It seems good. However, again my researched opinions said to stay away from the Ardex grouts.
    We like to use bricks. Rapid set thin set. This way the product is good to go the next day and not curing for 4 weeks.
    What! I would have to wait 4 week before covering it? I figured that by pouring a curb I could better control the design, especially if I reinforce it with small rebar or expanded metal mesh.
    Good Luck. Send me an email or call if you more questions. Give the guys above an email and confirm my posts.
    I can not say how well the process of seaming the Kerdi with 8+9 will hold up long term and my hunch is that perhaps the safest bet is to install the Kerdi the way Ardex outlines and if you want added protection to then use the Ardex SK mesh and NOT Kerdi Band for the second seam. The SK Mesh rocks and has holes in it to allow the product to lay down flat with no air bubbles trapped underneath.
    I asked about something other than open-weave fg mesh tape or bands as you suggest but local suppliers only have the fg stuff.
    I strongly advise you to do a test box with the Ardex 8+9 and purchase the proper paddle to mix it with. A test box should be preformed with any waterproofing system.
    That is a good idea, John. But still, given the cost of the 8+9 I don't want to break open the sealed box just for a test run. I would think all that [testing] has been covered in this forum?? That's one of the reasons why I'm here
    As for the paddle, I can only find the legacy-types like the one in the link above. And they seemed to mix thinset quite thoroughly.
  8. #23
    For a homeowner that doesn't have to deal with lots of tradesmen stomping around the construction site, the thickness of the membrane is not that big a deal. It also makes for less buildup in corners and overlaps. For a typical residential install, the difference in permeability is not generally a factor either. Once you cover it with tile, the thickness is irrelevant - is 1/8" glass more waterproof than 1/2" plate glass? Is one stronger, certainly, but at what cost. Prior to tiling, ANY membrane, paint on or sheet should be protected on the floor. If the backing material is solid, the walls pretty much take care of themselves. Use the stuff you have and don't worry, just be considerate of the material.
  9. #24
    Jul 2009
    North Vancouver, BC
    Default Ardex Schluter ten year warranty
  10. #25
    Aug 2010
    Cowichan, BC
    Thumbs up
    Good points you made here, John. There are only a few areas of concern regarding the gaps. And yes all the corners and seams are supported by blocking -- there is NO deflection anywhere. Now, I did not go to the extent and block every Hardi edge including putting blocking laterally ..that is, between the studs and along the bottom edges of the Hardi. They are however, supported 16" oc. In fact the back pony wall was built 12" on center.
    The only real concern was one corner where I forgot to extend the stud a bit more from the corner. So I had to run the screws in on an angle to catch the stud ..and still be at least 3/8" from the Hardi edge. The board is seated well on the existing stud though.
    I guess the boards could be taken down and rehung a little closer together, but that would still provide a gap at some other location. Another alternative would be to yank them and recut some new ones. All a BPITB. Your idea of mudding using some fg stucco mesh seems most feasible and I will use that to beef up those corner gaps and breakouts.
    To reiterate as appears in one of your other threads, when you did that full shower with 8+9 you actually thinsetted (with mesh) all the Hardi seams and corners before applying the 8+9?? If so, then that's what I will do as I agree that it makes less sense to just fill with 8+9 (and mesh) alone.
    As for scratch coating, that will be done when the seams are all taped -- thanks for that tip. I remember when the main bath surround was tiled with 12" marble, it took some practice to finally get the thinset to stick as the Hardi was so thirsty. I wound up pre-wetting the surface.
    And as for testing the product -- ok, you convinced me -- I'll follow some of your examples and test the product before use. Yer right, this is a one-shot attempt and I don't want to regret it later
    BTW, as an aside how much area does a box of 8+9 actually fully cover? ie, will one box be enough for a 3'x5' 3-wall (to ceiling) compartment?
    Regarding warranties ..methinks the replacement of Ardex materials might happen, but I doubt any labour, other materials, structural damage and the fact I am not a pro will most probably preclude any claim I might make So, I'm not too worried as long as I'm confident everything has been covered here.
    I will look forward to your "hand mixer" test soon. If your hunch works out then we can drop by a local thrift shop and pick one up ..providing they use the same type beaters
  11. #26
    Jul 2009
    North Vancouver, BC
    Default Mixing Ardex 8+9 with a mix master
  12. #27
    Aug 2010
    Cowichan, BC
    Question
    Quote Originally Posted by johnfrwhipple View Post
    Thrift Store mixer. Now that is an idea. I know if I sneak my wife's out she is going to kill me if I get caught. It would be my luck the morning I do the test she decides to make Pumpkin Muffins.
    ..but they will be waterproofed I just saw some new ones in XS cargo for $10. Beaters looked rather puny though. How thick is this stuff and will the handmixer be able to move it around?
    I still suspect the princess auto mixer will do the trick ..I've even seen very similiar but smaller ones in the $store.
    You will get about 70 square feet of coverage over Hardie Backer.
    I'm going to quiz you now before I answer your question.
    What is the number one reason for tile failure?
    Before waterproofing or tiling you need to know this. So Daler what's the answer. No helping Jim!
    I'll bite... poor bond? so, housekeeping -- making sure the substrate is clean, no dust. Meh, I was gonna vacume then lightly wash everything down anyway
    JW
    I suspect this thread may now be at risk of being hijacked by my own concerns. If need be it can be moved to another topic ..just lemme know where
    Are there any special concerns regarding the installing of large format tiles on the shower walls (ie, 12x24 & thinset considerations)?
    And for traction, we are thinking on putting in a natural 'sawn' pebble shower floor. To get full coverage/bedding of those rocks, can they just be fully embedded in gray thinset (like Ardex X5) without any topical grouting? Would it be best to be taken off their mesh backing and installed one at a time? What about water puddling?
    Also, I'm thinking on ordering a Better Bench from Amazon.com. I've read that they are the cat's ass for a nice simple easy-to-prep in-shower seat. What's your experience with them?
  13. #28
    Jul 2009
    North Vancouver, BC
    Default Hardie Board and Ardex 8+9 - watch out for bond breakers
  14. #29
    Aug 2010
    Cowichan, BC
    As long as we keep talking about Ardex 8+9 the thread has not been hijacked.
    Once you know the number one reason for tile failure you will approach every step forward with more care. It is one of my goals this year to teach my apprentice more theory and not have so many rules. If he understands why I have so many rules he can use this knowledge in multiple trades.
    There is a lot to absorb and lots to learn.
    So Daler. Once again - what is the number one reason for tile failure? You had it above.
    The number one reason for tile failure is "Bond Breakers".
    This is so important to remember. It also the number one reason for a waterproofing failure in my book. You need to clean and vacum the HArdie board. When you have it clean. Clean it again. Then tape with thin set and mesh. Leave this overnight with the S14 or three days with the X5. The scrap with a 3" taping knife and vacuum. Then clean. Then clean again. Then waterproof with the 8+9.
    Agreed. It was intuitive with me last time. Everything was super clean with the last project as it will be this time too. It's good that you reiterated this here
    Every step of the way you need to consider bond breakers. Your tile order should be shuffled and all cleaned. Then again before setting clean the backs. Do not have lots of water so wipe the cut tiles and let sit so they are clean but not wet.
    Bond breaker. Bond breaker. Bond breaker. I drill this into my appretice's head.
    Your question on thinset considerations is a timely one. I just got permission to share some scientific testing on the subject but have not had time to blog about it. I will soon.
    Along with your mixer results, as long as it's not to distant (we gotta get on this soon) I will look forward to reading about your thinset testing results too
    I've never used a better bench but have seen them at Ames Bros Tile. Looks like a very well made item. Will your bench be a floating one? If your waterproofing this bench you need to tie it into the walls and floor. The Kerdi inside corners can be flipped upside down to do the outside corners. If you order the Ardex 8+9 order a roll of the SK Mesh.
    Yes, the bench I have in mind is the floating corner one: BB30. And I am planning to encapsulate just the bench in either Kerdi or 8+9 or both (if your tests prove out) According to what I've read it can either be mounted to the Hardi and tiled around it or mount it after the tiles are up to give cleaner lines (and less micro-cutting). Jury is still out on either method as I have no experience with it.
    I guess the SK can be special ordered but a roll is way more than I will ever need and it is expensive. Can I not just use some heavy duty fibreglass mesh (similar to dw mesh tape but bigger holes and stiffer) cut into appropriate strips? I've got plenty of that.
    AS for the stone pebbles for the floor I'm finding that many suppliers are producing sheets that fall apart when soaked in water. We will not install an sheet tile until it has past a soak test.
    Do you have a sample of the floor tile? Get it in some water. Leave it two days. Remove tile and let sit for two days. What happens? You might notice rusting. You might notice an odor from the glue. The tile (stone rock etc) could just fall off the sheets. If any of the above happen you should abort your plan or remove rusting stones and loos set. You might want to grade the stones into 3-4 heights for loose setting. I recommend using a 3-4% grade for this shower base. Stone floors always drain slower.
    Reassuring advice, John -- thanks. We were into Tile Town recently and they showed me a sheet of the stuff. Any of those items are special order multiple sheets so getting a sample is not possible.
    It looked like the pebbles were very crudely glued on to a double mesh using glue sticks! As usual, I found that the more paid, the better the product -- and there was a huge spread in costs. The dealer also suggested soaking it first. And as you suggest, taking them off and thinsetting them each one separately. At least that way there is some assurance of full base coverage. On the mesh it looked like the pebbles were much too close for any grout to migrate fully between the stones -- hense my thoughts to just thinset the heck out of them individually and skip the grout. But now that opens up another concern about thinset "open" time when laying those rocks -- I can see myself being very anal about setting each individual pebble just right and feeling rushed before it sets up. How can I get around that (ie, with X5)?
    JW
  15. #30
    Jul 2009
    North Vancouver, BC
  1. Replies: 6
    Last Post: 05-26-2012, 03:38 PM
  2. Waterproofing a free standing tub surround. A look at various waterproofing options.
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 08-01-2011, 08:23 PM
  3. Schluter's Line Drain - A closer look at the new linear shower drain from Schluter
    Last Post: 07-15-2011, 07:47 AM
  4. A step closer to understanding health care in America
    By Ian Gills in forum Ian's Corner
    Last Post: 12-09-2010, 08:59 AM
  5. Green Particles
    By Cass in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2007, 12:59 PM
