Results 1 to 3 of 3
Thread: Oatey cast iron flange
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Default Oatey cast iron flange
    I am going to install an oatey cast iron flange over a 3" ABS pipe, then anchor it to the floor. Any tricks? The website provides little install info. A test fit showed it was very tight, and maybe a little "too tight" to get the screws on the brass clamp ring started. Use any lube? Just saying, it seems like it would work well, but maybe a PITA. J
    Why are you using a cast iron flange with an ABS pipe?
    Sep 2012
    Anaheim, Ca.
    I want the strength of a CI flange. The pipe happens to be 3" ABS. The Oatey fitting gives me both.
  1. Cast iron flange to J Tech flange
    By JP in VB in forum Toilet Forum discussions
    Last Post: 07-21-2010, 04:37 PM
  2. Cast Iron or PVC Flange?
    By BSwanson in forum Toilet Forum discussions
    Last Post: 05-23-2006, 07:47 PM
  3. Oatey PVC to Cast Replacement Flange
    By markc in forum Toilet Forum discussions
    Last Post: 04-17-2006, 09:04 AM
  4. Cast Iron Flange - Gone!
    By dlsteinberg in forum Toilet Forum discussions
    Last Post: 01-30-2006, 10:26 AM
  5. Cast iron flange or flange extension (?) below tile floor
    By gardengirl in forum Toilet Forum discussions
    Last Post: 12-31-2004, 09:54 AM
