Results 1 to 3 of 3
Thread: Resin replacement mesh size
    DIY Member dirtmover's Avatar
    Feb 2007
    Canada
    Default Resin replacement mesh size
    I've got a 13 year old GE water softener. Yeah, I know you probably all hate them but it has run flawlessly since I repaired the metering turbine 11 years ago. The softening capacity, however, is not what it once was and I'm assuming the resin may have reached the end of its life.
    I coincidentally happened across some resin locally at a great price which I snapped up but didn't realise that I was buying fine mesh and this softener has standard mesh out of the factory. Can this fine mesh resin be used in the softener or do I need a new screen and/or gravel bed?
    Yes you need the parts for fine mesh or you'll end up with resin escaping the softener into your plumbing and fixtures and appliances. An expensive and hard to correct mess.
    Nov 2010
    Maine
    A god awful mess. That stuff gets into the dishwasher solenoid, the washing machine, ice maker, toilet fill valves. It can cost a whole lot of money to have a plumber flush that stuff from the system.
  1. Moen Tub/Shower piping size & cartridge replacement...
    By Why did I try this? in forum Shower & bathtub Forum & Blog
    Last Post: 09-06-2012, 07:05 PM
  2. Ventilation Fan Replacement - Size Problem
    By golfer99 in forum Shower & bathtub Forum & Blog
    Last Post: 07-08-2012, 02:00 PM
  3. Proper resin tank size for 2 cubic foot softener?
    By FleckLander in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-22-2012, 05:50 PM
  4. Drywall - Paper Tape vs. Self Adhesive Mesh
    By CTWeekendWarrior in forum Remodel Forum & Blog
    Last Post: 12-22-2008, 08:32 AM
  5. Kinetico K60 resin replacement recommendations
    By Cory in forum Plumbing Forum Discussion & Blog
    Last Post: 07-12-2008, 09:53 AM
