Results 1 to 2 of 2
Thread: bathroom sink plumbing
    DIY Junior Member NYC-DIY's Avatar
    May 2011
    NYC
    Default bathroom sink plumbing
    Originally plumber installed supply lines a few inches higher than drain. (and few inches wider) But then realized that the drain was too low to fit inside vanity. They raised the height of just the drain rough-in and the supply rough-in are same height they were. So the question is... is it ok that the drain and the supply lines are the same height (from floor)? And if so is this going to pose a problem of them getting the drain rough-in to the bottom of the sink which horizontally will not be directly above the drain rough-in? (See rough sketch attached)Name:  vanity.jpg
    Thanks,
    Mark
    The water supply lines can come from almost anywhere. Sometimes they even come from the side.
  1. Question about plumbing under bathroom sink
    By kaeyreed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2012, 06:34 AM
  2. Tie Bar Sink to Existing Bathroom Sink Plumbing
    By kdpaparelli in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2012, 07:28 AM
  3. Trouble with bathroom sink plumbing - s-shape???? Need help fast!
    By nole01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2010, 06:06 PM
  4. Bathroom sink and toilet supply plumbing.
    By wwilson1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-07-2005, 07:16 AM
  5. Plumbing BathRoom Sink
    By merl4 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2005, 06:47 PM
