Results 1 to 5 of 5
Thread: Should 1/2" copper street ell be loose fitting?
    DIY Member DavidSeon's Avatar
    Jul 2012
    MS Gulf Coast
    Default Should 1/2" copper street ell be loose fitting?
    To avoid notching a stud I wanted to make a quick 90 downturn out of a shower valve cold inlet. I assumed I could use the male end of a 1/2" street elbow to keep the pipe away from the stud.
    But the male end of the Nibco ell I picked up at Lowe's is a pretty loose fit into the Moentrol inlet as well as other female fittings I tried. It looks like solder would fill it, but all the other connections I've made have been a pretty tight twist fit.
    Is this normal for st ells or am I trying to use the wrong fitting?
    Thanks, Dave
    Old Retired Computer Programmer
    Obsolete and loving it
    Sep 2009
    Seattle. WA
    It might be that the machined brass socket on the valve is more accurately round, and therefore "looser" than your typical
    commodity stamped copper fitting. But, yeah, I think NIBCO male street fitting ends might be on the smaller end of the
    acceptable range.
    Not all fittings are created equal...some are crap. Can't make a judgement on the ones you have, but the big box stores tend to buy the low-price bidder's product and there's often a reason why they're low cost.
    A "sweat joint" DEPENDS on a very specific tolerance between the fitting and the socket. IF it is too loose, (we had "feeler gauges" in the "old days" to judge it), the solder will NOT be attracted into the gap and you will wind up with a weak joint. You can "fill" a vertical joint with solder, but not an upside down or horizontal one.
    Jul 2012
    MS Gulf Coast
    Ok, picked up a Mueller street ell at a plumbing supply house, it fit the same as the Nibco. It soldered fine so I guess it was ok, just wasn't sure since it wasn't as snug as a regular pipe to valve connection.
    Thanks for the help.
  1. Replies: 27
    Last Post: 11-06-2011, 01:11 PM
  2. Any risks to merging two 3/4" copper water supplies? (using T fitting)
    By CJ-8_Jim in forum Plumbing Forum Discussion & Blog
    Last Post: 01-15-2010, 07:18 AM
  3. Loose fitting tail piece into extension pipe
    By MikeA in forum Plumbing Forum Discussion & Blog
    Last Post: 07-03-2008, 12:09 PM
  4. 90 degree copper T fitting 1/2"
    By DIY in forum Plumbing Forum Discussion & Blog
    Last Post: 06-21-2008, 06:45 AM
  5. How did "street" become fitting name?
    By gdavis62@adelphia.net in forum Plumbing Forum Discussion & Blog
    Last Post: 05-30-2007, 11:36 AM
