Thread: automatic pump
    DIY Junior Member aaaaaa's Avatar
    Oct 2012
    philadelphia
    Default automatic pump
    I am hoping to drain water from a collection tank once a day, i am just curious what sort of valve, timer, setup would be recommended here.
    A "manual pump" with an auxiliary float switch to prevent it from overfilling would be the first thing, then a timer in parallel to the float switch, so either one turns the pump on should give you what you want.
    Feb 2011
    NW Ontario, Canada
    More details might yield better suggestions. What sort of collection tank and why just once a day?
  1. Automatic syphon
    By jaco in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-16-2012, 11:45 AM
  2. Automatic sinks
    By brother in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2009, 10:06 AM
  3. Automatic Vents in MA
    By cooka111 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-01-2008, 07:57 PM
  4. automatic faucett
    By Peevee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2007, 04:50 PM
  5. Automatic or Non-Automatic Zoeller 267???
    By ryanwj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2006, 04:31 AM
