Results 1 to 5 of 5
Thread: KDF Application
Hybrid View
    DIY Junior Member themitch's Avatar
    Oct 2012
    Binghamton NY
    Default KDF Application
    Hello,
    I am looking for more information on using KDF-85 on a sulfur containing well water. I would like to know how well this works in conjunction with a GAC filter to provide filtered drinking water.
    Thank You,
    Brian
    IMO the best choice would be chlorination followed by Centaur carbon. GAC is not a good choice for H2S.
    KDF requires very high flow rates to backwash it and most private well water systems, and the pumps used, can not do it correctly.
    Jan 2012
    California
    KDF85 works very well for H2S removal, but... it requires considerable backwash water to do this. Check out the links, these will have the exact specifications you need to determine if KDF85 is right for you. If you have the backwash water available, then it may be an excellent choice and will provide many years of service, with very little maintenance. It is also an expensive media, but since many customers can get away with just using a single backwash tank without any chemicals, contact tanks, etc, the price may not be so bad.
    http://www.kdfft.com/success_hydrogen.htm
    http://www.kdfft.com/images/kdf_POESheet.pdf
    Oct 2012
    Binghamton NY
    Due to the pump in the well, I have no where near enough power for a proper back-flush. That is why I am looking to set up a small system for a small point of use. This filter setup would be for a water tap on a sink. In addition to this, I like experimenting with things. What I am looking for is getting 2 10" cartridge filter housings, a refillable cartridge, and a 1 micron ceramic filter. What I would like to experiment with is using a combination of the KDF-85 and some sort of carbon in the refillable cartridge, then after have the ceramic filter. The ceramic filter to clean out the IRB and what ever precipitates there will be, such as the copper monosulfide and ferric hydroxide.
    Brian
    Nov 2010
    Maine
    Take a look at this http://www.lancasterpump.com/documen...torAquaNue.pdf I am having very good results with it thus far.
  1. Dielectric Union Application
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2011, 06:11 AM
  2. efficiency in this application
    By Thatguy in forum HVAC Heating & Cooling
    Last Post: 12-26-2009, 09:29 AM
  3. Geo-thermal application
    By killerloop in forum HVAC Heating & Cooling
    Last Post: 03-26-2009, 06:04 PM
  4. ? Application of T plus 2 Rectorseal
    By handygirl911 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2006, 07:06 AM
  5. Best flux for 95/5 solder in air compressor application
    By Mike F in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2006, 04:57 AM
