Results 1 to 15 of 68
Thread: Necessity of Vacuum Relief Valve - Not Pressure Relief Valve
Hybrid View
    DIY Junior Member WillieK's Avatar
    May 2011
    Houston, TX
    Default Necessity of Vacuum Relief Valve - Not Pressure Relief Valve
    Hi everyone,
    My new water heater states: "Install vacuum relief in cold water inlet line as required by local codes". My inspector says I need one. I read on one of the old posts that you only need one if your water heater is on an upper floor or in the attic. Mine is in the attic. What is the purpose of a vacuum relief valve? What could possibly happen if I didn't install one - other than the inspector killing me?
    Thanks in advance for your help.
    It prevents siphoning of the water heater.
    If the water main is shut off to the home, and then a faucet is opened, it will siphon the water heater. When that happens, the top element burns out in seconds. With a non-functioning top element, you now have no hot water.
    Feb 2005
    Default not needed
    I have not heard that one in a long time....
    Inside most heaters today there is a port hole on the
    dip tube inlet at the top of the tank that prevents the
    heater from siphoning....... a heater cannot siphon down
    the valve they want you to install is not necessary
    quote; Inside most heaters today there is a port hole on the
    It is NOT to prevent siphoning. If the water supply to the building is turned off and the water is drained out, the tank will be subjected to "severe" negative pressure, i.e., a vacuum, and the amount of the negative pressure will be in direct corellation to how high the heater is above the drain point. The heater will withstand 300 psi of pressure but relatively LITTLE negative pressure so it will "collapse". If you have you ever seen a tanker truck that the driver opened the drain hose before he opened the lids, you have seen a collapsed tank and that was just the suction of a few feet between the truck and the ground. In Texas there was a city water storage tank that "imploded" and it was VERY impressive to see it look like an accordian. If you heater is in the attic, you DO need the vacuum relief valve, just as a safety measure.
    Feb 2011
    NW Ontario, Canada
    Ja, hj has the right answer. A vessel designed only for pressure should not be exposed to a vacuum. There have been documented cases of various tanks collapsing from the improper implementation of a booster pump as well. Water softeners have also collapsed from an improper drain line installation.
    THey're required where I live, regardless of where it is installed, as is a tempering valve. Really pisses off uninformed people when it comes time to replace their WH (assuming they get a permit), as it can add some to the installed price.
    Feb 2005
    If anyone has a water heater that has imploded or even a picture of one
    I would really like to have a picture of it for my web site....
    I feel like I am asking for a real picture of BIG FOOT
    send me those pics..... I
    am gonna Google imploded heaters and see what I can find
    http://www.homeownershub.com/plumbin...ater-2077-.htm
    send me what you got HJ
    Default tank
    Not a water heater but the same thing happens on a smaller scale with a water heater, since it also does not have internal baffles, (which pressure vessels such as a sumbarine do have to resist collapse from exterior pressure), to strengthen it.
    http://www.ebaumsworld.com/video/wat...?autoplay=true
    MPM, the "hole" is to prevent siphonage, NOT suction. Siphonage will only occur if a faucet is opened to let air into the system. Vacuum depends on the entire system being closed/sealed. In fact, if a faucet were opened so the hole stopped siphonage, it would ALSO break the suction and eliminate the need for a vacuum relief valve.
    Mark,
    Often when I'm draining down the house to do a pipe repair or to replace shutoffs, I loosen the flex connectors on the water heater to prevent the tank from siphoning. If it's electric, I just turn off the breakers at the panel so I don't let the water drop too low and burn out the top element.
    Siphoning happens. We just take the right steps, knowing that.
    In the city of Bellevue, if the electric heater is on the first floor, the vacuum breaker is not required, only if it's on a second or higher story.
    Water heaters will siphon!
    Feb 2005
    Default Terry ...you have a firm grip on the obvious
    Mark,
    I completely agree with you terry..... yes they will siphon
    till they hit the siphon hole on the dip tube in the heater..
    and sometimes its not a bad idea to open the t+p valve
    or something like you stated
    YES a water heater will siphon,
    but unless you put the heater to a test in an experiment
    to see how much negative pressure you need to use to make it
    implode..... the odds are it will never , ever implode. in a real world
    situation.....,,,
    I am gonna go get my power ball tickets now...
    its up to 169 million and my odds are better to win
    the power ball than see a water heater implode in my lifetime...
    on another note..... how have you been doing lately???
    feeling ok and all???.
  1. Pressure relief valve bad?
    By billy_pilgrim in forum Boiler Forum
    Last Post: 07-09-2009, 01:09 PM
  2. vACUUM RELIEF VALVE ON CLOSED LOOP SYSTEM?
    By CHRISUPNORTH in forum HVAC Heating & Cooling
    Last Post: 11-24-2008, 06:16 PM
  3. vacuum relief valve?
    By KKfromNJ in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-05-2008, 09:18 PM
  4. what is a vacuum relief valve for?
    By northman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-15-2007, 06:27 AM
  5. pressure relief valve
    By ttlcm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2006, 09:03 AM
