Results 1 to 5 of 5
Thread: I can't get this p-trap unscrewed.
    DIY Junior Member lukers's Avatar
    Oct 2012
    Minneapolis, MN
    Default I can't get this p-trap unscrewed.
    Any suggestions for removing this drain?
    DIY Member kevink1955's Avatar
    Nov 2011
    L.I. New York
    I am not about to be the one to open a link from a poster that has 1 post and just joined.
    Oct 2012
    Minneapolis, MN
    I am sorry sire, these are troubling times in the kingdom and your year spent tirelessly honing your craft on a forum shouldn't be wasted on a newbie. I am sorry to waste your time.
    It looks like you have already removed the slip joint nut, leaving only the brass ferrule behind. If you are removing the p-trap, then it's at the point where you can just pull it out now.
    Coming from the santee, you have a short galvanized nipple, then a brass trap adapter that should have had a brass ferrule and a slip joint nut. You may need to muscle it out of there.
    You may NOT be able to just pull it out. There is a lot of corrosion on the tubing inside the pipe. You can try twisting and pulling it so you scrape the stuff off, or cut the tubing at the face of the brass fitting and cut the brass tubing out with a hammer and screwdriver, or just unscrew the brass trap adapter and then remove the tubing or install a new adapter.
  1. P-Trap into floor drain? Or is that an S-Trap? (and not good)
    By bretm1 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-22-2011, 07:19 AM
  2. Help: Unscrewed well cap dropped part
    By eggman37 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-29-2008, 05:16 AM
  3. Lav trap on larger trap arm: actual problem?
    By dave148 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-07-2008, 07:34 AM
  4. Replace S-trap with P-trap or chicago loop?
    By staceyneil in forum Plumbing Forum Discussion & Blog
    Last Post: 03-05-2007, 08:06 AM
  5. Vanity sink trap - can I use 90's after the trap?
    By chassis in forum Plumbing Forum Discussion & Blog
    Last Post: 01-16-2006, 06:40 PM
