Results 1 to 7 of 7
Thread: 1" PEX or 1" PVC when hooking up new softener?
    DIY Junior Member JoshB-NC's Avatar
    Sep 2012
    North Carolina
    Default 1" PEX or 1" PVC when hooking up new softener?
    All the current connections and piping in my well house are 1" PVC. The softener and Filox filter are both 1" pipe connections. I have been told by numerous people to use PEX instead of PVC. I have the pex tool and I have done plumbing with both. Its just that the ID of the pex is quite a bit smaller than PVC. Does it matter??
    Its a well system JRD10 pump 30/50psi.
    PEX handles heat better. PVC is rated for use underground.
    Sep 2012
    North Carolina
    The well house has the jet pump and bladder tank all plumbed with pvc. The pvc then goes through the slab of the well house under ground 80' or so to the house.
    I was going to use 1" pex from water pump to filter and softener then tie back into the larger 1" PVC where it exits the pump house.
    I just want to make sure I am not going to lose volume or pressure inside our house because the 1" pex is quite a bit smaller than 1" PVC (ID).
    Maybe its a dumb question? I just want to do it right!
    PEX is smaller, so for a water service many people recommend bumping the size to 1-1/4"
    Nov 2010
    Maine
    Ya can't use PVC inside the house but you can in the well house (go figure) so since everything else is PVC you might as well stick with it.
    PVC is much easier to use and less expensive overall and that's what you already have. I'd use PVC.
    Sep 2012
    North Carolina
    Ok thank you!
  1. Clack WS1 type softener-no suction-have tried "everything"
    By DOCSCANTLIN in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-27-2012, 03:10 AM
  2. Softener hookup issue - 1" bypass, 3/4" Main
    By adawg in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2010, 02:09 PM
  3. "Machine Gun" or "Thud" and a Weeping Toilet...oh my!
    By maxxis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2009, 07:38 PM
  4. Difference between "thinset" and "dryset" mortar...?
    By Fistor in forum Remodel Forum & Blog
    Last Post: 07-31-2008, 02:44 PM
  5. Say "no" to the AS Champion toilet & "yes" to Toto
    By badeb in forum Toilet Forum discussions
    Last Post: 04-18-2006, 09:32 AM
