Results 1 to 12 of 12
Thread: Is this a drain? (above water softner loop)
    DIY Junior Member RobHydell's Avatar
    Oct 2012
    Florida
    Default Is this a drain? (above water softner loop)
    I want to add a water softener and don't want to make assumptions. Is this a drain that I can use for the softener's backwash? Thanks in advance for the help.
    The inlet and outlet at the bottom of the picture go to my whole house water filter.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Quote Originally Posted by RobHydell View Post
    looks like a drain for a W/M standpipe.
    DIY Junior Member Brokersdad's Avatar
    Nov 2011
    canada
    Think i'd take the end off of it and go to other areas of the house and run some water to see if you can hear it passing by the pipe to make sure it was in fact some type of drain. Who knows what people do when building
    Sep 2009
    Seattle. WA
    You don't want to make assumptions ... so you get on the internet and ask folks who can't possibly know even as
    much as you about that pipe, and ask THEM to make assumptions ... ?
    Yakima WA
    This place was plumbed by a handyman. All of that PVC pipe is a dead give away. So, there's no way to tell by looking. You may have to open the wall to figure it out.
    Pour some water into the pipe and see what happens. You have a catastrophe in the making with that PVC piping inside the house.
    Nov 2010
    Maine
    But the guy at Home Depot said that it was the best stuff to use
    Oct 2012
    Florida
    Quote Originally Posted by Winslow View Post
    Thanks for the information.
    PVC piping can't be used inside the home. That should be removed and replaced with CPVC or PEX
    PVC is only rated for use underground where the temperatures can remain cooler and constant. Using PVC for domestic hot water is a real NO-NO.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Just guessing, but the pipe in question could also be a "cleanout".
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by kreemoweet View Post
    LOL... so true. I assume it is a combustion air supply.
    it could be, but the configuration is all wrong for a cleanout, especially since it does not appear to have a removable cap or plug. If it were a washing machine drain, then where are the hot and cold water supplies a WM would need.
  1. Softner Drain freezing
    By hobiecatter in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-07-2012, 09:14 PM
  2. Kenmore water softner: Water going in drain pipe continuously
    By gagan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-21-2010, 12:34 PM
  3. Water Softner Drain to Black PVC 5" with Cap
    By weneedhelp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2007, 02:03 PM
  4. Culligan mark 100 water softner water flowing to brine line all the time
    By seahawk99ca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2007, 09:35 AM
  5. Loop for Dishwasher Drain Pipe
    By lpennington in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2007, 08:33 PM
