Results 1 to 2 of 2
Thread: Sched 40 pipe 2"
    DIY Junior Member syncman's Avatar
    Oct 2012
    Marietta GA
    Default Sched 40 pipe 2"
    Spa problem. Cut between 2 PVC fittings to remove a cracked part. No pipe was showing, so I cut between the 2. This means no pipe showing to glue the new fitting. The remaining fitting is a 5 port flange that is not cracked.
    http://www.****.com/itm/2-S-PVC-Mani...685?pt=LH_Defa...
    This is really locked in there. To change that as well would mean re-piping half the tub, plus a lot of insulation stripping. Is there a "repair fitting, coupling, elbow " that would go INSIDE the remnants of the 2" pipe, instead of outside? Maybe a different diameter pipe? A pipe Hog wont work because of all the pipes from another manifold are in the way.
    There are "inside" couplings, but good luck finding one. Normally it would be a special order and you would have to buy a "boxful" of them, but try here http://stores.drainageproducts.us/-s...ule/Detail.bok
  1. "real-world" vintage cast iron pipe cutting?
    By zimmee66 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-04-2013, 01:07 PM
  2. Shower Steam Generator Pipe in Contact with "Pink" Insulation
    By JuanSigned in forum Plumbing Forum Discussion & Blog
    Last Post: 01-30-2011, 04:52 PM
  3. What is best/safest way to cut cast iron drain pipe (or "undo" the fittings)?
    By diecastdawg in forum Plumbing Forum Discussion & Blog
    Last Post: 01-19-2010, 10:53 AM
  4. Do I really need the "Water Stop Device"? (Washing machine inlet pipe)
    By Mr Skills in forum Plumbing Forum Discussion & Blog
    Last Post: 11-18-2008, 05:47 PM
  5. Sched 40 or 30?
    By HemiMoparGuy1981 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-11-2008, 02:13 PM
