Results 1 to 3 of 3
Thread: Pex Crimp rings or Clamp rings....Which Preferred ?
    DIY Junior Member Its.me.again's Avatar
    Oct 2012
    Buffalo, NY
    Default Pex Crimp rings or Clamp rings....Which Preferred ?
    Since I am new to pex...and just a homeowner...I figured I'd ask which pex fastener is preferred.
    Do you like the solid copper Crimp rings or the stainless Clamp rings?
    Is there a time when you prefer one application over the other?
    THere's a third choice - Uphonor's expansion rings. THey all work, I'm not sure there is a big difference on the crimp rings. I prefer the Uphonor's system, but it does require a more expensive tool to install (a tubing expander rather than a crimp tool). WIth this system, you insert the tool into the tubing, expand it, slip it over the fitting, then the pex (with the reinforcement ring) collapse over the fitting. Pex has memory and I like the fact it makes the seal on its own rather than relying on it being compressed. But, done right, they all work. By expanding the tubing, there's less restriction at the fitting, too.
    Pex is made in one of three methods, and designated as -A, -B, or -C. -A is the most flexible and the only one that can have a kink repaired. -B and -C types require you to cut out the kink and insert a fitting. Plus, -A bends to a smaller radius, often requiring fewer fittings.
    I use both, on the few occassions when I use PEX. The clamp/cinch rings are convenient because the same tool does them all without changing "dies".
  1. What tool to use to crimp PB fitting? What color crimp rings do I use?
    By CountryBumkin in forum Plumbing Forum Discussion & Blog
    Last Post: 11-17-2012, 07:26 AM
  2. Two rings, or not two rings, that is the question.
    By SugarHollow in forum Toilet Forum discussions
    Last Post: 09-06-2012, 07:48 AM
  3. Pex-copper rings -stainless steel clamp
    By JOE1934 in forum HVAC Heating & Cooling
    Last Post: 06-30-2007, 12:24 PM
  4. Which is better ?Wax Toilet Rings vs Wax-free Toilet Rings
    By herbolaryo in forum Toilet Forum discussions
    Last Post: 05-31-2007, 12:06 PM
  5. Crimp Rings VS. Compression Fittings
    By Desperado in forum Plumbing Forum Discussion & Blog
    Last Post: 02-08-2005, 11:31 AM
