Results 1 to 2 of 2
Thread: Pex ring removal tool (Sharkbite 23055) Adjustable or not?
    DIY Junior Member Its.me.again's Avatar
    Oct 2012
    Buffalo, NY
    Default Pex ring removal tool (Sharkbite 23055) Adjustable or not?
    I am new to pex tools (I am just a homeowner) but am buying some for working on friends mobile home water lines.
    OK..... so I buy the 23055 pex ring remover tool at one Home Depot store. Then I go to another different Home depot store in the area a couple of months later and see the same tool, but this one has a tiny plus/minus knob to adjust the cut.
    Which one of these a newer version of the same tool? Also is this tool used to cut both "Crimp" and "Clamp" bands?
    Even when I look on the Sharkbite website I swear I am looking at misrepresented pictures of products. Like they show the Crimp ring tool pictured with clamps...etc.
    Thank you
    The clamp//cinch rings, which I think you are referring to, are stainless steel so it is unlikely the ring removal tool would cut them. I can't imagine why the removal tool would have a +/- setting because all it has to do is cut through the ring into the tubing, which is NOT a precise cut, since you already has to cut the tubing at the fitting to get into it.
  1. Moen Shower Cartridge Removal Tool
    By HawkeyeSean in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-10-2013, 06:23 AM
  2. Stem Removal Tool
    By Nancy McGuire in forum Shower & bathtub Forum & Blog
    Last Post: 06-01-2011, 01:31 PM
  3. Water heater anode rod removal tool !
    By MACPLUMB 777 in forum Water Heater Forum, Tanks
    Last Post: 08-06-2009, 11:24 PM
  4. Dropped a screw removal tool down drain.
    By Ryde41 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-02-2009, 02:13 PM
  5. Tool for bath tub drain removal
    By garyl53 in forum Shower & bathtub Forum & Blog
    Last Post: 03-02-2007, 12:18 PM
