Results 1 to 5 of 5
Thread: 2 lights on same circuit controlled by 2 switches
    DIY Junior Member lynams's Avatar
    Oct 2012
    Texas
    Lightbulb 2 lights on same circuit controlled by 2 switches
    I have a 3 switch plate on my wall. One switch is for an indoor light switch ( 3 wire, as there are 2 on the same line). The other 2 switches are two separate outdoor light fixtures. I am replacing 2 outdoor (motion sensor) light fixtures that are controlled by 2 switches. Originally, the two lights were connected together by a very thin, 3-connector(?) flat cable which is also being replaced. The first light when replaced by itself worked, but when I turned both switches on it now stops working. I am still trying to get the first one (closer to the switch) to work.
    The old flat cable did not have colored wires, didnot help me with how the two lights were connected, except the middle wire was wired around the cable itself, or not used.
    How do I make sure I have them connected right and both to operate?
    THANKS.
    Sep 2009
    Seattle. WA
    You look at the installation instructions that came with the fixtures!
    Thin flat wires are not typical for line voltage. WIthout being there, it's hard to say if the original installation was correct.
    Basically, if one light works, you'd parallel the wires (black/white/ground or hot/neutral/ground) from one to the other. Thin, flat wires may be low-voltage control cable from the remote sensor to the light fixture, not power.
    Hard to say without being there.
    From your description, we do not know if those are even "3 way switches", or how you are wiring the lights and switches together. WE would need a lot more information to even try to diagnoes the problem.
    Jun 2007
    North Carolina
    Quote Originally Posted by lynams View Post
    Is this three switches in one box or what?
    Three wire? Is this one black one white and one bare and two what on the same line and what is the line?
    If the two lights were on two different switches why would the very thin three conductor be doing between these two fixtures that are on two different switches?
    If it worked why are you still trying to get it to work?
    Again why were these two connected together if they were on two different switches?
    Maybe if you could post pictures of the switches we could help but your post doesn’t make any sense.
    THANKS.
    Your welcome
  1. 15A outlets/switches on 20A circuit
    By maurice53 in forum Electrical Forum discussion & Blog
    Last Post: 05-29-2011, 11:42 AM
  2. Four 3-way switches, two lights, two ganged device boxes.
    By Lightwave in forum Electrical Forum discussion & Blog
    Last Post: 12-13-2010, 11:00 PM
  3. Adding 4-way switches to a 3-way lighting circuit
    By cej22 in forum Electrical Forum discussion & Blog
    Last Post: 11-14-2009, 07:39 PM
  4. lights on GFI protected circuit
    By pmayer in forum Electrical Forum discussion & Blog
    Last Post: 11-02-2009, 08:40 AM
  5. Two lights on Two 3 way Switches...Only one comes on?
    By IPictureU in forum Electrical Forum discussion & Blog
    Last Post: 05-06-2008, 05:57 AM
