Results 1 to 5 of 5
Thread: Why is my drain vent so tall?
Hybrid View
    DIY Junior Member Crassius's Avatar
    Oct 2012
    Virginia
    Default Why is my drain vent so tall?
    My vent pipe is very high.... about 7 feet tall.... to high to see if there is a nest or something that needs clearing near the top. Its of PVC.
    Does it need to be so tall?
    I am thinking of breaking a joint so I can access it.
    Is it on a deck or other area where people could get to it? THe installer may have extended it above the ridge of the roof to avoid downdraft problems.
    Feb 2011
    NW Ontario, Canada
    A picture may help.
    DIY Senior Member Hairyhosebib's Avatar
    Jun 2010
    Arizona
    Get a garden hose in the pipe and turn it on. If water does not overflow out of it then it is either clear or you cleaned it out with the hose.
    The only way ANYTHING could be in it, without falling to the bottom, would be if it were overhanging the sides, and you would be able to see that.
  1. In-wall vent for waterfall drain?? Air Admittance Valve or cheater vent
    By conroyt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2012, 07:47 PM
  2. 4" Cast Iron toilet drain too tall
    By panawop in forum Toilet Forum discussions
    Last Post: 11-30-2008, 07:33 AM
  3. Flange just a bit too tall for toilet
    By kenliu in forum Toilet Forum discussions
    Last Post: 05-17-2008, 05:59 PM
  4. Flange too tall for new toilet
    By fishin49 in forum Toilet Forum discussions
    Last Post: 05-13-2008, 12:36 PM
  5. Flange too tall?
    By C1aire in forum Toilet Forum discussions
    Last Post: 08-17-2006, 05:47 PM
