Results 1 to 6 of 6
Thread: Portable dishwasher question
    DIY Junior Member skittles's Avatar
    Oct 2012
    Ontario
    Default Portable dishwasher question
    I have a portable dishwasher and as a result my facets keep leaking due to the back pressure. I would like to know if its possible to get an under the sink attachment that I could open and close that could somehow be long enough to pull out and attach to the dishwashers adapter and leave them in the kitchen sink (for drainage). This could bypass my faucets. Any suggestions are appreciated.
    "back pressure" does not cause leaks. Faucets are designed to operate under the full pressure of the line. You have a bad seal wherever you see the leak. Repair the faucet
    quote; Faucets are designed to operate under the full pressure of the line.
    Not true. Spouts are NEVER subjected to "full pressure" when operating normally. When a dishwasher is connected, then the flow is interupted and then they get full pressure, which is not what the spout hoses and seals are designed for. There is no connection which will work the way you are asking, unless you modify the dishwasher hose and cut off the end, which would mean it could not be used the intended way again unless you replaced the hose unit.
    There are quite a few million portable dishwashers out there . I strongly suspect that faucet manufacturers take that into account/ Most spouts I have seen are radial o-ring seal....the same type of seal we use on 3000 PSI hydraulics and 4500 PSI air, in my 'former life'.
    I think the weak spot would be the stem seal on the faucets, but these should also be "OK" He has something wrong which can be repaired, and far more easily than jury rigging something under the sink!!!!
    Sep 2009
    Seattle. WA
    I have had to replace (with a faucet of different design) numerous kitchen faucets with pull-out spouts, because they failed when used with a portable
    dishwasher. Some faucets with pull-outs are now being made such that the dishwasher adapters cannot be installed at the outlet.
    quote; I strongly suspect that faucet manufacturers take that into account/ Most spouts I have seen are radial o-ring seal....the same type of seal we use on 3000 PSI hydraulics and 4500 PSI air
    Do you REALLY think faucet manufacturers worry about, or design a faucet, to handle a portable dishwasher. They do NOT consider that a "normal use" for a faucet. Did that 3,000 psi hydraulic or 4,500 psi air connect "rotate" the way a spout does or did they have 3000 and 4500 psi "clamps" around them?
  1. portable dishwasher help
    By neili in forum Plumbing Forum Discussion & Blog
    Last Post: 07-11-2011, 04:25 PM
  2. Whirlpool Portable dishwasher
    By coop0230 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-22-2009, 03:01 AM
  3. portable dishwasher splashing problem
    By Linda M in forum Plumbing Forum Discussion & Blog
    Last Post: 12-29-2008, 08:05 AM
  4. Portable dishwasher hook up
    By Oiram in forum Plumbing Forum Discussion & Blog
    Last Post: 02-09-2007, 02:38 PM
  5. install Portable Dishwasher
    By plasma_22 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-14-2005, 08:06 PM
