Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: New water well
    DIY Junior Member dENNIS MEYER's Avatar
    Oct 2012
    TEXAS
    Default New water well
    I'm planing on having a 4'' well driled it should be about 250' deep. I would like to save myself some money by installing the submersible pump myself. There will be two people one strong & one week . If I install using threaded pvc pipe do you think the two people could do it ? Is there a clamp that I could buy that would hold the pvc pipe in place to keek the pump from falling in the well, to add another length of pipe ?
    If you have suggestions on what else I could do,I'm all ears.
    Thanks for any help you can give me
    Dennis
    Feb 2011
    NW Ontario, Canada
    They do make and sell clamps specifically for the job but I just use a wood block clamp.
    If you want to go big...
    http://www.americawestdrillingsupply...PipeClamps.asp
    Oct 2012
    TEXAS
    Thanks for the clamp info. I have been trying to find out some information on the pvc pipe not having much luck. I would like to know is it male on one end & femail on the other or are they both male ? I would also like know what the weight per 10, length would be ?
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by dENNIS MEYER View Post
    I would never trust threaded PVC female ends so would use M/M with SS couplers.
    Jan 2008
    I too would avoid PVC couplings. 1-1/4" schedule 80 drop pipe is about 60 lbs per 100 feet.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Depends on the PVC couplings. We use sch 1" 120 pipe with sch 120 couplings here all the time down to 700' with no problems.
    The biggest problem you will have using sch 80 is holding it steady & straight up n down while you screw it together. See if you can rent an up z dazy with a halo, it will make life much, much easier and safer too!
    Better yet, call a pump guy with a good solid reputation and have him do it. He has all the equipment, the knowledge, and the job will be guaranteed.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    I found myself without my hoist the other day replacing a twin-line jet for a sub. The location was too wet for the truck (38' boom). We screwed all the pipe in on the ground (stainless couplings) and ran it in one string. It's tough to tape the wire good to the pipe doing it like this...but we only had 3 joints. Everything went well. You can use 1" sch 80 PVC...no need for 1.25" pipe unless you're using a high volume pump. A pair of vice grips works really well to hold the pipe for taping etc. Squeeze em down tight, you won't hut the pipe.
    Just make sure you get the wire tight (no slack in the well) and get everything ready first including the well seal at the top (a piece of tape under the well seal will hold it in place. cut the wire 2-3 ft above the well seal and put it through. I always put a junction box right at the well seal anyways.
    Good luck!!
    Feb 2010
    SE Texas-Coastal
    They make it both ways....but the pipe I'm familiar with is sch 80 with male ends on both sides (threaded). They make some stuff that is MXF so you don't need to buy any couplings. I use stainless or brass couplings but you can use galv. if you have good water. If you do use galv. make sure you tape the couplings up. As a rule I avoid putting galv. pipe in a pvc well unless the whole string is galv. Brass/Stainless couplings are about $10-15 retail.
    What is the water level in the well and how much GPM does it make?
    Dec 2009
    northfork, california
    Wrong pipe. Use Poly 160 psi in ONE piece and slip it all in in one shot.
    Feb 2010
    SE Texas-Coastal
    You'll probably have to special order the 160 or 200 psi poly here in Tx. It's just not carried at many retailers.
    Oct 2012
    TEXAS
    Thanks for all the good replies. If I go with the polly, what would be the best way to fasten to pump ? Would I have to splice two rolls togather if so what would the best way to splice it be ?
    Thanks to all.
    Dennis
    Feb 2011
    NW Ontario, Canada
    I would use one long roll, not two shorter ones to avoid a splice. A long barb fitting should be used at the pump.
    Apr 2012
    ct
    No you can get poly in 100', 200', 300', 400, & 500' rolls. You need to use a male x insert adapter that is made of the same material the pump is. For example, stainless pump, stainless adapter. But for a few dollars more you can buy sch 80.
    I have heard of people screwing sch 80 together on the ground and running it in, but I have never done it.
    Personally, I hate seeing a submersible in a well hung on poly. The stuff is designed for being in a trench. Why? Go pull out a few hundred feet of poly. In addition to the stuff having a memory and wanting to curl up, it's all over the yard, in the dirt & dog crap, the wire gets knots in it...... Sch 80 can be laid out on blocks to keep it out of the dirt, you can get the wire taped off so there is no slack, the wire can be rolled up on a reel when the pump needs to be changed....it's just makes for a nicer, cleaner, more professional installation with a far less chance of picking up and transferring surface contamination to the well.
    Feb 2011
    NW Ontario, Canada
    Not a DIYer option but for a pro, the P5 solves those issues.
    http://www.youtube.com/watch?v=q11rJVAKCrs
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    its made by doc brown from back to the future.
    looks like a big pita. glad we dont have poly here, pump hoists are easy.
