Results 1 to 6 of 6
Thread: triangle tube prestige 110
    DIY Junior Member mark161's Avatar
    Oct 2012
    ma.
    Default triangle tube prestige 110
    looking for wiring info using a taco SR 503 switching relay with a prestige 110 boiler
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    Taco XX terminals is wired low voltage 18-2 wire to prestige TT terminals
    If Payback is so important to you, why are you not driving a Toyota Corolla?
    DIY Junior Member TerryP's Avatar
    Jan 2013
    Toronto
    My TT boiler is cycling but it is skipping the space heating mode (3) and only heating the domestic hot water. The domestic mode (4) heats to as high as 204, according to the display, then shuts down having reached the temperature set point. The display then flashes 6200, followed by code b 18 (supply temperature too high). Am I not getting space heating because the supply temperature is too high?
    Master Hot Water Mpls,MN BadgerBoilerMN's Avatar
    Mar 2011
    Minneapolis
    If the TT is set for domestic hot water and unable to satisfy this first priority, it will not leave the task. Who set the boiler up?
    It could be as simple as the temperature sensor for the IWH is not seated properly, or not working properly. Is the IWH temperature excessive?
    DIY Junior Member Machinist's Avatar
    Oct 2012
    Ithaca, NY
    Terry,
    What was causing the issue with your TT skipping space heating mode? Is it a Prestige 110 that has been in service a while? A followup might be helpful for others.
  1. Replies: 48
    Last Post: 04-16-2014, 07:56 PM
  2. Replies: 9
    Last Post: 10-15-2012, 11:27 AM
  3. Can the Triangle Tube Boilers Be Programmed?
    By Ferretman in forum Boiler Forum
    Last Post: 02-11-2012, 08:42 PM
  4. Triangle Tube Prestige Excellence Boiler Use
    By Offsite in forum Boiler Forum
    Last Post: 12-18-2011, 08:23 AM
  5. Solo110 with smart40 indirect hot water heater triangle tube
    By Brian Morgan in forum Water Heater Forum, Tanks
    Last Post: 04-24-2009, 09:33 AM
