Results 1 to 5 of 5
Thread: Inline frameless shoot door
    DIY Junior Member NYC-DIY's Avatar
    May 2011
    NYC
    Default Inline frameless shower door
    doing an inline frameless shower door about 58" wide with 1/2" glass. Will consist of one fixed panel and the door. Door will be hinged on the wall and be about 26-30" and NOT go all the way to teh ceiling. The panel will be the remaining width and will be hooked with clips. Was trying to decid on 3 options for panel. 1) have it go all the way to ceiling and attached at floor and ceiling. 2) have it same height as shower door and only attached with clips at side and floor and use support bar off teh top. 3) 2) have it same height as shower door and only attached with clips at side and floor. Im leaning towards 1 or 3. So my qustions are: How much wobble in #3 and is this unsafe? How bad does #1 or #2 look?
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by NYC-DIY View Post
    I never specify shower clips on the ceiling or floor. I do not like any penetrations in my shower's waterproofing system at all. Since I mostly build topical waterproofed showers I do not let the glazers drill into my floors.
    There is many ways to achieve the same look without the clips.
    Do you need the glass to go all the way to the ceiling?
    What type of waterproofing are you using in this shower?
    Is there a shower curb? How was it built?
    JW
    May 2011
    NYC
    I don't need the glass to go to ceiling, but I'm considering it just for stability. Would a 30-32" fixed panel that is only attached on side and bottom be stable?
    Not built yet, but will be a topical waterproofing I think. How do you not allow glaser to drill into it? How else would they attach glass? And why worse to puncture ceiling or floor than to puncture wall?
    Curb will be standard 4x4 mortar curb built as part of the shower pan.
    Mark
    A glass panel that is only "stabilized" at the bottom and one side will be VERY delicate, especially if you should stumble and bump into it. Either use a top rail to secure the top edge or run the glass all the way to the ceiling so it can be attached there.
    DIY Junior Member stevenjames's Avatar
    Feb 2014
    Virginia
    I frequently build relevant waterproofed showers I do not let the glazers make a hole into my floors. There is lots of ways to get the similar look without the clips.
  1. Frameless shower door install
    By thebigsee in forum Shower & bathtub Forum & Blog
    Last Post: 12-01-2009, 07:44 PM
  2. Frameless Door and Walls out of Plumb
    By bluemax2 in forum Shower & bathtub Forum & Blog
    Last Post: 04-11-2008, 02:33 PM
  3. Frameless shower door and Glass Block install
    By crosby1 in forum Shower & bathtub Forum & Blog
    Last Post: 02-07-2008, 05:36 PM
  4. Frameless shower door enclosures
    By davidtaf in forum Shower & bathtub Forum & Blog
    Last Post: 03-06-2007, 04:11 AM
  5. Replies: 0
    Last Post: 05-15-2006, 02:20 PM
