Results 1 to 13 of 13
Thread: Pipe says ABS, everything else says it's PVC.
    DIY Junior Member ghetterly's Avatar
    Jun 2009
    Saskatchewan
    Default Pipe says ABS, everything else says it's PVC.
    Hello!
    I have a couple of questions and I hope I won't come across as too dense.
    1. I have a Kohler tub/drain to install this weekend in my main bathroom. The drain (K-7213) is made of white plastic pipe. The manual that came with the drain, the website I bought it from, and Kohler's website all say it's made of PVC. The pipe itseld has ABS Sch40 case into it. I'm thinking it's ABS and I can use my normal (yellow) ABS solvent cement on it.
    2. I will be picking up a Vespin II from Terry's early in November. Anyone have any reasonably priced tickets to the Seahawks game on the 4th they want to sell? Or where do buy tickets for Seahawks games? I've looked at a number of pretty sketchy websites.
    Thanks, Greg!
    Yakima WA
    Very interesting. PVC is white, ABS is black, but as you point out, the white fitting you have says ABS so ???. PVC and ABS are different chemically and require different solvents ("cement") What presents a problem is that neither of these so called "cements" are glue or cement. They are solvents that melt the top surfaces of the fittings and pipes so they actual form a weld when jointed, and since PVC and ABS are different chemically, you don't mix and match the solvents. There is a product that will work on both PVC and ABS, but you must be certain that you get the right thing. I know of no yellow "cement", but perhaps it is for CPVC that is used for interior water supply lines It should say what it is for on the can.
    Nov 2010
    Maine
    Both PVC and ABS can be manufactured in any color including clear.
    DIY Junior Member michaeljj's Avatar
    Oct 2012
    new york
    PVC and ABS both are very different and requires different chemical composition to lay off. Here as you said that your pipe is ABS and else is PVC. That may be right but you need to contact them or your vendor to determine the right way to put it or the "yellow cement" you talking about.
    broan parts
    Sep 2009
    Seattle. WA
    Is there perhaps another marking on the other side of the fitting? Evidently some factory molds are used to make plastic fittings of diverse
    materials, and they carry different ID markings for each. I've heard about the yellow ABS cement widely used in Canada, but never seen it.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    I bet they used the wrong mold for making the fitting and no one looked at it before you. In fact sometimes you'll see a raised printing that says, "WHITE PVC [model no] BLACK ABS [model no]." If you put PVC solvent on ABS it will just sit there. If you put it on PVC, it will get soft.
    what colour is the solvent for DWV ABS in the US? i have only seen yellow....grey is for PVC and purple is pvc primer....and white solvent for ABS-PVC transition...
    If you want to be safe, use the green "transition cement" which works on either rmaterial.
    Quote Originally Posted by mikeplummer View Post
    Commonly, regular PVC cement is clear, heavy duty is gray, ABS black,
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Are you talking about the solvent itself, or the label on the can?
    Yakima WA
    It's the color of the solvent itself. I'm still skeptical about ABS sometimes being white, but I don't profess to be a pro so I won't stand a stand on that point. I think HJ has the best short term answer, use the transition cement that works on both ABS and PVC.
    when im talkin colour, im referring to the solvent itself...i wasn't sayin abs solvent is white....mine is always yellow....the white is ABS to PVC transition glue
    Jun 2009
    Saskatchewan
    Thanks for the input everyone!
    No other markings on the pipe or fittings in the kit, just the "ABS" ones like the picture.
    I think I will go with the transition cement just to be on the safe side.
  1. Concrete Pipe 90 bend flush with basement floor. How to connect new pipe?
    By Johnbentwin in forum Plumbing Forum Discussion & Blog
    Last Post: 08-22-2012, 05:50 PM
  2. Branch Pipe of Cast Iron Waste Pipe COMPLETELY clogged! HELP!!
    By vintshave in forum Plumbing Forum Discussion & Blog
    Last Post: 06-24-2012, 07:00 PM
  3. Use Clay pipe or cast iron pipe for overhead sewer (50-60ft underground in yard)??
    By bnbhoha in forum Plumbing Forum Discussion & Blog
    Last Post: 04-01-2011, 06:17 AM
  4. Plastic Pipe Insulators / Brackets thru Studs for Copper Pipe -- When Required?
    By speede541 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-11-2011, 10:44 PM
  5. replacing drain pipe with RIDGID Model 246 Soil Pipe Cutter
    By texasitty in forum Plumbing Forum Discussion & Blog
    Last Post: 08-14-2008, 06:25 AM
