Results 1 to 7 of 7
Thread: How do I remove BLFC from Fleck 6700XTR head?
Hybrid View
    DIY Junior Member cgarai's Avatar
    May 2012
    Sonoma County
    Default How do I remove BLFC from Fleck 6700XTR head?
    I am trying to find out what the actual size of the BLFC is. Do I need a special tool and if so, where do I get it?
    Thanks,
    Chris
    There should be a sticker on or close by to the brine and drain line connections that lists how many gpm slash lbs per minute. Or call the people you bought it from and ask them what's in it.
    Jan 2012
    California
    a regular screwdriver will work. Fleck does make a special tool, but this is only really needed by the assemblers or guys whoe service them regularly. You need to remove the drain fitting from the drain/brine assembly, you will see that inside the drain port, there will be a plastic retainer with 4 slots in it. Insert a crewdriver blade into one of the slots and carefully unscrew the reateiner from the housing. Remove this part and the button will be easily removed. Remeber, number go toward the valve when ou reinstall the button. The button will have numbers on it that indicate the flow rate.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Dittohead, he was talking about the BLFC not the DLFC. The BLFC is located in the brass piece that the brine tube connects to. You would have to remocve the brass piece and inside is a white plastic holder. Use needle nose pliers to remove the plastic holder to get to the BLFC. I would not do thid because most of the time the plastic hloder is torn up trying to remove it and if you don't have a replacement, you can not put it back together. you can use a measuring cup and time it. .5 BLFC = 2 cup in 15 sec
    Jan 2012
    California
    Quote Originally Posted by mialynette2003 View Post
    LOL, thanks for that correction. I read that post after I played 2 back to back hockey games, and after a 20 hour day.
    You are spot on. Remove brass fitting, needle nose... the flow rate is molded into the rubber flow controller. The sticker should tell you, or you can simply put a 5 gallon bucket and calculate the flow.
    May 2012
    Sonoma County
    Hi,
    Thanks, actually I miss-spoke and meant the DLFC, so Dittohead's response to miss-reading my message was just the ticket! Thank you both, as both pieces of info are useful.
    Chris
  1. How to remove Well Head?
    By amateur plumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-23-2012, 11:12 AM
  2. Salt Dosage and Fleck 6700XTR, or any head for that matter
    By cgarai in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-03-2012, 08:50 PM
  3. How do I remove the brine piston assembly at the control head of a Fleck 2510?
    By Biddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-01-2011, 09:22 PM
  4. How to remove or change old rotating shower head with wide connection?
    By Scott99999 in forum Shower & bathtub Forum & Blog
    Last Post: 01-02-2011, 07:24 AM
  5. can't remove old shower head
    By janicef in forum Toilet Forum discussions
    Last Post: 07-11-2005, 03:31 PM
