Results 1 to 4 of 4
Thread: I'm an idiot! - Bathtub drain pipe question
    DIY Junior Member madforrit's Avatar
    Sep 2012
    Bay Area, CA
    Default I'm an idiot! - Bathtub drain pipe question
    Hi everyone, first post here. Looks like a great forum and happy I found it.
    I'm in the midst of installing a bathtub, and for reasons I can't explain, I measured only once (ugh) and cut the brass tail (drain?) pipe too short. Can I extend the pipe by soldering on a coupler/union, and if so, what kind of coupling am I looking for? I purchased a 1-1/2" copper coupling for the bath drain pipe (1-1/2" OD) but it's entirely too large...clearly I am missing some very basic knowledge here. A short length of brass pipe with threaded ends that could be used with slip nuts would also work, but I don't know if such a fitting exists. Or do I need to buy a whole new assembly because of my stupidity?
    Sorry for what I am sure is a very naive question - I'm an advanced DIYer in everything BUT plumbing. I appreciate the help!
    Sep 2009
    Seattle. WA
    There probably are tubular drain fittings you could use, but you're not likely to find them outside a specialty plumbing outlet if you insist on using
    brass (a very old-fashioned and expensive way to go). Slip-joint extensions as short as 4" are available. Tubular drain pieces (such as you are using) do
    not mix with copper DWV (drain, waste, & vent) items except via the use of special adapters. Similarly with Schedule 40 plastic and galv. steel DWV
    pipes. Dimensions in each of those systems are "nominal".
    There are tailpiece extensions for tubular drain pipes available - I think I've even seen them at a big box store, but more selection available at a plumbing supply house. These usually come with a beveled compression washer and a nut to make the seal.
    Sep 2012
    Bay Area, CA
    Thanks guys. I picked up a tailpiece extension at the big box store. Did the trick.
  1. Trying to remove bathtub drain from lead pipe
    By hercules2424 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-09-2011, 05:41 PM
  2. bathtub drain question
    By congaman59 in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2010, 06:22 AM
  3. bathtub drain down pipe issue
    By lee polowczuk in forum Plumbing Forum Discussion & Blog
    Last Post: 07-17-2007, 05:34 AM
  4. Stupid Bathtub drain question.....
    By UPEngineer in forum Shower & bathtub Forum & Blog
    Last Post: 03-21-2007, 07:51 AM
  5. Running a drain for bathtub question
    By trinculo54 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-19-2005, 02:02 AM
