Results 1 to 3 of 3
Thread: Bathroom Remodel Pressure Test
    DIY Junior Member swiederin's Avatar
    Apr 2012
    Iowa
    Default Bathroom Remodel Pressure Test
    I remodeled my sencond floor bathroom and used PEX for the first time. I would like to do a pressure/leak test before putting the new flooring down. How can this be done? Never done that before.
    If the new pipes are connected to your current system, it's a bit too late.
    They system needs isolation so that the pressure can be contained. If the system is off line so to speak, you can use a hydrostatic pump attached to a valve to pressurize.
    Frankly, if it's holding water, I'm sure you're fine. PEX either leaks or it doesn't.
    Jan 2008
    If you are handy, you could make up an air fitting with a schrader valve to pump up the system with a bicycle pump. You will need to have valves in place to isolate the section which you want to test.
  1. Pressur Test Bathroom DWV System
    By cava0035 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2007, 05:46 PM
  2. Air Pressure Test
    By nelsonba in forum Remodel Forum & Blog
    Last Post: 08-09-2006, 07:45 PM
  3. pressure test
    By smakcaine in forum Plumbing Forum Discussion & Blog
    Last Post: 01-16-2006, 06:49 AM
  4. DWV pressure test
    By Oliver in forum Plumbing Forum Discussion & Blog
    Last Post: 10-15-2005, 07:11 AM
  5. Pressure test
    By trinculo54 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-23-2005, 02:04 AM
