Results 1 to 5 of 5
Thread: Conversion from gas furnace to electric furnace
    DIY Junior Member
    Oct 2012
    Israel
    Default Conversion from gas furnace to electric furnace
    Is there an easy way to convert a gas furnace to an electric furnace?
    Thanks in advance
    It is quite easy. You tear out the gas furnace in its entirety. Then you pay an electricial quite a bit of money to upgrade your service and install a very high-amp 220 circuit to the furnace location. Now you purchase a brand new electric air handler, and have the electrician hook it up.
    Sorry to be a bit brusque, but there would be no such thing as a "conversion"
    Jan 2009
    In Israel's climate replacing a gas furnace with an air source heat pump (ductless or ducted) would be far preferable to a resistance-electric furnace, since you'd also get the benefit of air conditioning. The average efficiency of heat pumps will be quite high in heating mode in that climate too, EXREMELY efficient if you get a better version with continuously variable speed compressors/blowers, using only ~20% of the average power of a resistance-element furnace. Most apartments & houses in Israel could be heated and cooled reasonably with a single ductless mini-split.
    DIY Junior Member kyleanderson's Avatar
    Jan 2013
    manchester, kentucky
    there are such a unit and it called a duct heater. you install a metal sleve in you duct past supply and install duct heater, the right size wiring for rating of heater. stat for electric heat, because your stat is for gas. there is a drifferents. and that about it. code here say 12in before and after heater. we installed them all the time in geothermal units. but heat pump would save you 2/3 and maybe more to use.
    A co worker of mine had an electric plenum heater (i think that was the term)installed on his fuel oil furnace. In this area with electric at .04 off peak per kwh he saved more than the cost of the upgrade in his 1st year. Now if your on natural gas I dont know if it would pay. Certainly if you have fuel oil or propane it might be worth a look.
    Politicians are like diapers. You need to change them often……for the same reason.
  1. Propane to Natural Gas conversion on furnace
    By Willie Two in forum HVAC Heating & Cooling
    Last Post: 10-20-2011, 04:47 AM
  2. TIme for new furnace . Gas or electric?
    By Sparky240 in forum HVAC Heating & Cooling
    Last Post: 01-30-2011, 10:16 AM
  3. electric furnace
    By antietam in forum Boiler Forum
    Last Post: 10-13-2009, 08:20 AM
  4. What furnace should we get?
    By Sincraft in forum HVAC Heating & Cooling
    Last Post: 09-02-2007, 01:13 PM
  5. Gas furnace vs. electric heat
    By YTHOMAS in forum HVAC Heating & Cooling
    Last Post: 04-27-2007, 07:41 AM
