Results 1 to 6 of 6
Thread: Kitchen Faucet Replacement
    DIY Junior Member diynewbie123's Avatar
    Oct 2012
    Toronto
    Default Kitchen Faucet Replacement
    Hello, we were looking to replace out old faucent, when the old one developeda pin hole. We had the counter top, sink, and faucet changed over 10 years ago by a contractor. Unfortunately there is a metal piece that is hindering us from removing the assembly. There den't seem to be any screws or nuts holding it in place but seems to be connected to the counter top. Any advice or insight to this issue would greatly be appreciated.
    Thank you,
    Andrew
    There is a small nut holding the clamp to the counter top.
    It's too bad it presses against wood. Wood can compress, and the faucet gets looses.
    Oct 2012
    Toronto
    We figured that there would be something as such. But there doesn't seem to be any way to access it from either the top or the bottom. The contractor might of installed it while installing the counter top making it difficult to make any replacements without removing the whole thing.
    You can plainly see the nut in your photo.
    A basin wrench might get it, or, if you have a deep socket on an extension, you could loosen the nut that way. You might get an open end or combination wrench on it to loosen it up. Once loosened a bit, you can probably spin the nut by hand to remove it.
    Channel Lock pliers might work too.
  1. Attaching faucet supplies to Premier Kitchen faucet
    By Jfree in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2012, 04:13 PM
  2. Kitchen faucet replacement
    By Jerpop in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-15-2011, 01:32 PM
  3. Kitchen Faucet Replacement...problems with leak and cold water valve won't shut off
    By RSMBob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2011, 08:07 PM
  4. bathroom faucet and kitchen faucet have low pressure
    By aprylreign in forum Shower & bathtub Forum & Blog
    Last Post: 11-30-2008, 10:55 PM
  5. Kitchen Sink Replacement
    By hrsnblm in forum Remodel Forum & Blog
    Last Post: 12-13-2005, 03:01 PM
