Originally Posted by
Runs with bison
I'm wondering if the short life of the PRV's in my home plumbing is related to the sprinkler system. Unlike the previous homeowner that apparently thought he was growing corn, I only use the sprinklers during extended dry periods/drought...all of this summer unfortunately and now extending through fall. When each station first comes on the line has to be inventoried and the high flow rate results in a noisy valve chatter from the PRV as it is running out the end of its performance/flow curve--sounds like a gasoline motor firing up for several seconds.
Thoughts?
