Results 1 to 15 of 15
Thread: drain trap problem
    DIY Junior Member brianv's Avatar
    Oct 2012
    Fresno, CA
    Default drain trap problem
    I have a leak at the union of the drain trap to the pipe from the wall. I've tried using one washer, two washers, teflon tape. No matter what I try I still have a leak. I almost got new washers but that doesn't make sense as the ones I have are in good shape. Now I'm thinking of getting a different trap but I don't see what difference it would make. I'm frustrated. And yes I'm a plumbers worse nightmare an amateur diy'er.
    The order in which you tighten the slip joints and compression seals in a tubular trap can make a difference. If it is twisted when you try to tighten it, it may not seal. If the taper is pointing the wrong way, it will never seal, either.
    Oct 2012
    Fresno, CA
    None of the washers packed with the trap when I got it were tapered.
    Is this a metal or a plastic trap?
    Oct 2012
    Fresno, CA
    plastic trap.
    Most plastic traps don't have a washer on the swivel joint.
    Loosen all three nuts, and then start by tightening the swivel nut first. No dope, no tape.
    Then tighten the other two slip joint nuts.
    Oct 2012
    Fresno, CA
    There are only two nuts.
    Then you better post a picture. Sight unseen is kind of tough.
    I install p-traps that have a slipjoint at the wall, one on the swivel and one for the tail piece.
    Yakima WA
    Isn't the third nut attached to the trap adapter? I haven't done that many P trap connections and none for sometime and I don't have perfect memory, but it does seem to me that the trap adapters I bought had a nut on them.
    Oct 2012
    Fresno, CA
    I will try to be as specific as possible. I have a metal elbow coming out of the wall that bends down at a ninety degree angle. It is 1.5 inches diameter. It is not threaded at the end pointing down. I also have a plastic pipe coming straight down from the drain. It is 1.25 inches diameter. I have a plastic trap with three nuts an assortment of washers and two plastic adapters. I have put the plastic trap on and I have a persistent leak from where the plastic trap slips over the metal elbow even though I have used a washer and tightened the nut. Everything else seems to be fine. Neither of the two plastic adapters fit over the 1.5 inch metal elbow. I have even tried to fit a washer down in the plastic trap to the point where it goes down to 1.25 inches but that hasn't worked. I'd like to be done with this, this is the third day I've been at this. If I have to go buy more stuff I will but I think I have everything I need.
    So in other words, you have a combination of parts from different manufacturers all cobbled together.
    Oct 2012
    Fresno, CA
    Yes. I don't even know if I can get the metal elbow from the wall to come off so I can start over from there. I know I would have to break the wall to do it.
    Nov 2010
    Maine
    You can't go from the plastic U bend to the metal elbow. You either need all plastic or all metal.
    I think you're going to have to break down and buy some new parts there pardner. Don't worry. It will keep the economy going if you splurge on some new fittings. If you have a plastic pipe coming out of the wall, that's where you would glue a trap adapter. Buy some glue, it will buy someone lunch somewhere, and all that good karma will come back to you. Pick up a plastic trap that uses the trap adapter near the wall. check to make sure the tailpiece is going to work with it too. If this is for a lav, that would be 1.25". Some p-traps have two slip joint washers for the tailpiece, one for 1.5 and one for 1.25. Either way, you're going to be good buddy.
    Sep 2009
    Seattle. WA
    Most plastic p-traps are made to use a beveled washer at the swivel joint. You can get nylon or "rubber" beveled washers at any hardware store.
    Mix-and-match doesn't usually work too well with tubular drain parts.
  1. P-Trap into floor drain? Or is that an S-Trap? (and not good)
    By bretm1 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-22-2011, 07:19 AM
  2. Offset p-trap problem
    By house84 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-20-2009, 04:22 PM
  3. Lav trap on larger trap arm: actual problem?
    By dave148 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-07-2008, 07:34 AM
  4. P Trap Problem Please help!
    By ryanfinnan in forum Plumbing Forum Discussion & Blog
    Last Post: 07-27-2007, 09:53 AM
  5. Toilet drain - trap or no trap?
    By mwolf1954 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-22-2005, 07:05 AM
