Results 1 to 4 of 4
Thread: Installing Wirsbo PEX, have some install detail questions
    DIY Member DaveHo's Avatar
    Mar 2010
    SE PA
    Default Installing Wirsbo PEX, have some install detail questions
    I'm replacing PB tubing & am running the PEX through some of the same framing holes that it used. I'm using the color coded tubing & have noticed the colored coating is being rubbed off in some spots where it passes through framing. I'm only noticing this on the hot supplies. I can wiggle the tubing in the holes. It does not feel tight & it is not making noise at these points when expanding. However due to the slight curvature the tubing has from being coiled it is rubbing lightly. Granted the colored coating is not as tough as the tubing itself, I can scratch it off using my fingernail without much effort. Is the tubing eventually going to rub through at these spots or am I stressing over nothing?
    Secondly, I'm getting expansion noises between the tubing & some of the tube talons/hangers. I can easiliy slide the tubing through these by hand, the colored coating is not rubbing off, yet they are making noise once the tubing heats up & starts expanding. How do I solve this?
    I'm an experienced DIY'er, I've read the Uponor install guide, & watched a ton of you-tube videos. However, none of these really cover some of the nitty gritty details you can only get from experience with the product. Are there any other tricks or finer details someone would be willing to offer?
    -Dave
    Mar 2010
    SE PA
    Nobody? Do I need to redo some of my work & enlarge the hole or is coating being rubbed off not an indication the pipe is going to rub through? Been fighting PB leaks for the last couple years & would sure appreciate some input as I don't want to be back in the same boat after going through all this work.
    -Dave
    I either use the plastic fittings to secure the PEX, or put some foam insulation around the PEX and hang it. The PEX should have room for expansion.
    I've never had a problem with PEX.
    Nov 2010
    Maine
    The holes should have at least 1/8" clearance around them. Constant rubbing probably will cause premature failure of the pipe. Go to www.souixchief.com and look at the products they have for pex penetrations, hangers and bend supports.
  1. questions about installation detail
    By diyfun in forum Remodel Forum & Blog
    Last Post: 03-07-2012, 12:56 PM
  2. questions about installing vessel sink
    By dooo42 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2010, 05:20 PM
  3. Installing Pex Questions
    By kskier in forum Plumbing Forum Discussion & Blog
    Last Post: 03-22-2009, 07:37 AM
  4. DVW, Cleanouts, in detail--Cleanout specs
    By civ2100 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-08-2007, 07:28 PM
  5. 2 Questions ?? Venting / Aquapex by Wirsbo
    By enosez in forum Plumbing Forum Discussion & Blog
    Last Post: 01-27-2007, 09:05 AM
