Results 1 to 8 of 8
Thread: Square D 2 pole breakers
    DIY Senior Member rockycmt's Avatar
    Nov 2007
    New York
    Default Square D 2 pole breakers
    I was in Hdepot this weekend. I was looking for a 2 pole SqrD 20Amp skinny space saver breaker. Do they make these? I see them in the other brands there.
    DIY Junior Member Glennsparky's Avatar
    Oct 2012
    Oviedo, FL near Orlando
    Call your local Square D distributer. That breaker is called a quad. Square D makes QO style and Homeline house breakers. They don't make QO quads. They may make Homeline quads.
    Many SqD replecements are made by Connecticut Electric. They are UL listed replacements, and they make both the QO and Homelines, which are not interchangeable . They will be clearly labeled as to SQUARE D Type...... A thin 2 pole 20 should be available.
    quote; That breaker is called a quad.
    A "quad" is a two pole breaker with FOUR levers, not a single pole with two levers, which is what this person is asking about. Incidentally, WHY do you need this double pole breaker? Not for a 220/240 circuit, I hope. In addition, in order to limit the possibility of overloading the panel, they usually restrict the location and number of "piggy back" breakers you can install. They do not always fit in every single pole slot.
    Oct 2012
    Hi hj. I'm sure what you describe is called a quad, however, this link
    http://www.lowes.com/pd_3989-296-HOM...facetInfo=Quad
    is a product that is also called a quad. It is also the only answer to rockycmt's question that I know.
    Oct 2012
    I couldn't find any Square D replacements on Connecticut Electric's website. This product
    http://products.connecticut-electric.com/inventoryD.asp?item_no=UBITB220C&CatId={7DF35B55-1A7B-4294-BC01-656D1BCDF640}
    may physically fit in a homeline panel, but it is not listed for it. So, not legal.
    Sorry, I can't get this link to work. Can anyone help?
    Looks like I mispoke. SOMEONE makes replacements, but it appears it is not connecticut. Of course, OEM Schneider ( SQ D) are available now also. A few years ago, they were off the market because of a massive chinese forgery/fakery problem.
    Glennsparky. He is looking for a single device breaker with two terminals. They can come in a "half sized" format with the two levers side by side, or piggy back with the two levers in the same plane. But in either case they are on the same polarity and only require a single slot on the panel, assuming the slot is not one which "rejects" tandems. "Quad" breakers usually have a "double pole" breaker and two single poles.
  1. Power to a pole barn
    By lipripper in forum Electrical Forum discussion & Blog
    Last Post: 03-30-2012, 08:34 AM
  2. triplex breaker 20/20/20 single 2 pole 20a, dual COMMON TRIP 1 pole 20a?
    By mrpedal in forum Electrical Forum discussion & Blog
    Last Post: 03-01-2012, 08:32 PM
  3. Pole Vault
    By Southern Man in forum Electrical Forum discussion & Blog
    Last Post: 10-13-2008, 07:07 AM
  4. 1 pole, 2 wire or 2 pole 3 wire switch for water heater?
    By bigtime in forum Electrical Forum discussion & Blog
    Last Post: 11-04-2007, 05:13 PM
  5. 240v single pole?
    By hids2000 in forum Electrical Forum discussion & Blog
    Last Post: 08-11-2007, 07:37 AM
