Originally Posted by
mialynette2003
Have you checked the venturi? A lot of times the venturi can get a piece of debris stuck in it and cause the problem you describe. Remove the venturi, hold it up to the sky and look through it. You should see a perfect circle of light blue. Any obstruction will be noticed. If there is something obstrcuting it, use something that will not scratch the inside like a needle. I use a straw from a broom or something simular. Do not force anything inside the venturi. If you need parts, I can supply them.
