Results 1 to 7 of 7
Thread: 4 Inch PVC Sewer Line Through Cinder Block Foundation Wall In Crawl Space
    DIY Member DanMcD's Avatar
    Jun 2005
    Dayton, OH
    Default 4 Inch PVC Sewer Line Through Cinder Block Foundation Wall In Crawl Space
    Do you need a protective sleeve to bring a 4 Inch PVC sewer line through the hole in my Cinder Block Foundation Wall?
    My plumber says no. Also, they seal the hole so water does not enter my crawl space.
    Your plumber has it right.
    IF you put a sleeve around the pipe, then you have to seal the sleeve AND the pipe. THe only time I use a sleeve is when I give it to the block layers and they put it into the wall and I run the pipe through it later.
    Jun 2005
    Dayton, OH
    Thanks Terry and HJ. Nice to know my plumber knows his stuff.
    DIY Junior Member JoshRountree's Avatar
    Nov 2009
    Fleetwood, NC
    Depends on the code, in NC any time pipe is run through a foundation wall it must be sleeved.
    Jun 2005
    Dayton, OH
    So what is the reason/rationale behind the code in NC to require using a sleeve any time time a pipe is run through a foundation wall?
    A sleeve might allow you to replace the pipe at some later time without having to break the wall. Depending on the temperature extremes, a sleeve might allow the pipe to expand and contract without rubbing on the concrete. Some soils swell and shrink depending on their moisture content and a sleeve might allow a little flexibility so the pipe isn't rubbing or flexing directly in the concrete wall.
  1. Is It OK (For My Pipes In The Crawl Space) If I Disinfect The Crawl Space With Bleach
    By LAnewplumber in forum Plumbing Forum Discussion & Blog
    Last Post: 08-13-2012, 10:05 AM
  2. Cutting door in foundation block wall
    By Giles in forum Remodel Forum & Blog
    Last Post: 12-26-2009, 07:47 AM
  3. Sewer line break in rubble-filled crawl space
    By neverenoughtools in forum Plumbing Forum Discussion & Blog
    Last Post: 12-21-2008, 11:57 AM
  4. How to drill 2.25" hole in cinder block wall?
    By TigerDriver in forum Plumbing Forum Discussion & Blog
    Last Post: 08-24-2008, 08:10 AM
  5. Replacing Cast Iron Sewer Lines In Crawl Space
    By DanMcD in forum Plumbing Forum Discussion & Blog
    Last Post: 04-29-2006, 07:46 PM
