Thread: sealing unions?
    DIY Junior Member hmarkn's Avatar
    Jan 2012
    British Columbia
    Default sealing unions?
    Hi:
    I was wondering if any more experienced plumbers can assist me with this. I recently witnessed a company that was applying teflon tape and pipe dope to a brass union on an antiscald valve for a bath tub. In my experience (I have only been plumbing for less than 5 years) with brass unions such as those on a pressure reducing valve, the rubber (or fibre) gasket was sufficient for sealing it. Am I correct in thinking that the small rubber gasket with built in strainer on these unions is sufficient for the seal, and that the tape and dope is not necessary? Or am I wrong. As I said, I have only been plumbing for a few years and welcome any more experienced feedback. Also, I am plumbing in Canada so not sure if any Canadian plumbers can correct me if the code here says otherwise. I don't remember reading it but I haven't received all the updates since I got my ticket.
    Thanks.
    The only time you need to seal the pipe joint with pipe dope or tape is on a tapered pipe thread. Any other connection is sealed with some sort of gasket (like a hose on a hose bib). It doesn't hurt to put a little pipe dope on the mating surface of a union, but tape will often create a leak.
    Putting tape or compound on a gasketed joint does absolutely NOTHING to help it seal. Compound on a ground joint union help seal any small imperfections which could cause leaks.
  1. unions and pex
    By ginahoy in forum Water Heater Forum, Tanks
    Last Post: 09-12-2009, 05:08 PM
  2. Brass Unions
    By BimmerRacer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-21-2009, 01:13 PM
  3. Unions. Yes or NO?
    By Master Plumber 101 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2009, 10:21 PM
  4. Water heaters and unions
    By Agu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-22-2009, 08:00 AM
  5. Using Unions
    Last Post: 04-22-2009, 02:06 PM
