The charger is easy to test with a DC voltmeter if you are familiar with such.
Any 12V automatic charger will work for this system.
The "Zoeller" charger is some other brand of charger/maintainer with their label on it.
Well, I think I done goofed first when I heard a huge bang in my basement and my battery literally blew up in the case (thank goodness it was contained). I would suspect my maintenance free die hard was not truly so and the water levels got low.
I got a new battery and hooked it up. The yellow light does not come on for the charger. I would assume this means the charger is toast as well?
The problem is how to replace this charger if this is the issue. The charger is very much wired into the switch/pump so to speak in this setup.
Any ideas how to proceed with this assuming I am correct with the charger not working anymore?
The problem would also be how to wire it in. The charger is wired into the system via the switch and pump and of course battery. This might be a replacement candidate:
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
Figure 3 here shows what I am talking about:
https://app.qleapahead.com/rtp/libra...sset=115816,63
The extra (blue) lead on the Zoeller charger is for the alarm, and has nothing to do with keeping the battery charged or the operation of the backup pump. If you feel that you need the alarm function, you could buy a replacement charger from Zoeller, or you could install a separate high level alarm in your sump.
Thoughts on the link to the charger on Amazon? I think that would work just fine. I don't need an alarm. Thanks again for all the help....
The specs on the charger look fine.
Whether or not it is a good quality product is questionable.
This looks familar- no?
http://tinyurl.com/9su38at
[QUOTE=jucs;357773]This might be a replacement candidate:
Battery Tenders ar very good products. I have four in full time service at this very moment. A battery tender will NOT charge a dead battery or one that has an extremely low charge ......... at least this is what I have found. However, they will maintain a good battery and ensure it is "topped off" as needed.
You really must research "GENIUS" battery chargers. Made in the USA, epoxy sealed and 5 year real warranty. They do float charge and main charge automatically. Good price and no chinese parts to burn up. http://www.geniuschargers.com/products
